Stock F250 Spring Block?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 06-12-2017, 08:46 PM Thread Starter
Diabolic1's Avatar
Does this look stock for the rear of a 97 F250?
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 27 (permalink) Old 06-12-2017, 09:00 PM
Schneider 86's Avatar
Re: Stock F250 Spring Block??
The larger bottom block looks normal. However, the smaller block on top, I do not think those are there stock.
Schneider 86 is offline
post #3 of 27 (permalink) Old 06-13-2017, 06:27 AM
Project Shamu
Lt.Dan's Avatar
The very top one looks like a pinion shim, is it tapered front-to-back?
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #4 of 27 (permalink) Old 06-13-2017, 09:54 AM
alleged moderator
tjctransport's Avatar
bottom is stock. the other one is added for around a 1 inch lift.
tom
tjctransport is online now
post #5 of 27 (permalink) Old 06-13-2017, 02:39 PM Thread Starter
Diabolic1's Avatar
So it sounds like I need a 4" block. Combined I have a total of 3" now. I wAnt an extra inch in back.
1997 CCSB, 7.3/E4OD
post #6 of 27 (permalink) Old 06-13-2017, 06:13 PM
csp
Go to an OBS F350 block.
csp is offline
post #7 of 27 (permalink) Old 06-13-2017, 11:22 PM Thread Starter
Diabolic1's Avatar
What is the softest riding spring I can put back there? I'm about to add Firestone bags for towing so I can afford softer springs. Where can I buy the stock F350 block? How tall is it?
1997 CCSB, 7.3/E4OD
post #8 of 27 (permalink) Old 06-13-2017, 11:25 PM
Project Shamu
Lt.Dan's Avatar
Softest spring? Ive heard 2008+ f350 rear springs, but you have to relocate the spring hangers because they are longer.
Lt.Dan is offline
post #9 of 27 (permalink) Old 06-13-2017, 11:43 PM Thread Starter
Diabolic1's Avatar
What about excursion springs?
1997 CCSB, 7.3/E4OD
post #10 of 27 (permalink) Old 06-14-2017, 12:12 AM
alleged moderator
F250 uses a 2 inch rear block, F350 uses a 4 inch rear block.
both use the same springs.
tom
