Hey guys, just curious what everyone is doing for fuel mods on an
OBS? I see TONS of threads for the
SD, but not the
OBS.
I ask because I believe i'm getting air into my fuel system, something fierce. Enough to be hearing the injectors ticking from starvation (I believe).
Right now i'm running a custom E-fuel with stock
SD Pump, and pre and post filters.
Thinking about the Hutch mod thats on
guzzle7pt3's website, but I'm unsure if its the same for the
OBS, and if its the same for the rear tank as well? Can't find the info there. I would like to do a sump pickup, but I will loose capability of the fuel selector valve, and only having an 18 gallon tank sucks... Also thinking about the 5/8" pickup tube from Strictly Diesel, but again, I either have to deal with one tank, or somehow adapt it to work with the selector valve.
If I have to loose a tank, I think I'll just remove the front tank, and run the Spectra F26E tank for the rear. 38 Gallons, and then run the 5/8" pickup tube to my
SD pump. But i would like to avoid spending too much money if i can.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
