7.3 needing help can't figure this thing out!!! Any ideas! - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #1 of 44 (permalink) Old 06-06-2017, 03:40 PM Thread Starter
Rayaubrey's Avatar
Hello to all,
I have a 96 F350 with 7.3, I done everything to this engine and can't figure out why it's doing what it's doing. Can't hook scanner up to check codes it early early 96 model with factory 95 Motor according to vin number. I've replace icp, ipr, hpop, fuel pump, idm, wiring harness, all injectors, rebuilt fuel bowl, new glow plugs, low pressure oil pump, new orings on oil cooler, I don't know why it's doing this has anyone came across something like this???
It will run for about 5 sec when you first start it then check engine light comes on then sound like half the injectors shut off. I have a video but can't post
Rayaubrey is offline
post #2 of 44 (permalink) Old 06-06-2017, 03:56 PM
Moderator
Sbluke55's Avatar
Re: 7.3 needing help can't figure this thing out!!! Any ideas!
Check the fuse in #16 in the under dash fuse box.
c-case7.3 likes this.
01 f-250, Standard
Sbluke55 is offline
post #3 of 44 (permalink) Old 06-06-2017, 04:00 PM Thread Starter
Rayaubrey's Avatar
1996 7.3 help!!
I have a 7.3 that I have done everything I can think of to do to fix it and it still will not run right. It will start but after about 5 sec of running and sounding perfect the check engine light comes on and sound like half the injectors shut down. I have all ready replaced the icp, ipr, idm, all injector, Lpop, hpop, fuel pump, fuses and relays, don't really know what else to do. Any ideas or has someone had this problem before.
post #4 of 44 (permalink) Old 06-06-2017, 04:01 PM
What device are you using to attempt to scan it?
madpogue is offline
post #5 of 44 (permalink) Old 06-06-2017, 04:02 PM Thread Starter
Rayaubrey's Avatar
Used one made by snap on
post #6 of 44 (permalink) Old 06-06-2017, 04:04 PM Thread Starter
Rayaubrey's Avatar
I was told by ford tech, that only the ford scanner would work. It's a 1996 Centaurus
post #7 of 44 (permalink) Old 06-06-2017, 04:17 PM
There are others that will work. WHICH Snap-On did you use?
madpogue is offline
post #8 of 44 (permalink) Old 06-06-2017, 04:20 PM Thread Starter
Rayaubrey's Avatar
MT2500
post #9 of 44 (permalink) Old 06-06-2017, 04:34 PM Thread Starter
Rayaubrey's Avatar
What does that control?
post #10 of 44 (permalink) Old 06-06-2017, 04:50 PM Thread Starter
Rayaubrey's Avatar
Which one will work?
