Left bank dead all of a sudden - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-30-2017, 06:00 AM Thread Starter
Took the family from Portland to Bend this weekend to coach in a baseball tournament. No problems on the 200 mile drive and back and forth to games. Loaded everything up at noon to come home and truck starts and then proceeds to run on only one bank. Left bank exhaust is completely cold. Ran a buzz test and can hear all 8 injectors. Got codes for high to low circuit fault in #2 and #4. While it's loping at idle I can pull the harness connector from #2 and #4 an no change in idle. Got an IDM code error as well. Needing to get home and nothing open on Memorial Day I have it towed. Got home and pulled the drivers side valve cover off expecting to find melted gasket or UVCH's and found neither. Fired the truck off and no oil from any injectors on that side. I'm thinking IDM failure from what I've researched but don't want to order one until I know and don't have a spare available. Anything else to look at? Oil was just changed before trip and at the right level.
97 F250 California Model, down pipe, DP Tuner, ATS intercooler, 170K, Beans electronic fuel delivery, gutted EBPV
Kruegerk is offline
post #2 of 6 (permalink) Old 06-02-2017, 09:05 PM
Re: Left bank dead all of a sudden
Still having the issue? What are the actual codes? (Note - words aren't codes, codes are.)
Listen again on the buzz test. If you can, you or a helper stand in front of the truck, dead center in front of the blue oval on the hood. Make sure when it buzzes, you actually hear it alternate side to side, right, left, right, left, etc.
madpogue is offline
post #3 of 6 (permalink) Old 06-03-2017, 12:18 AM
Crankcase's Avatar
I bet the Israelis are ecstatic!!!!!
Crankcase is offline
post #4 of 6 (permalink) Old 06-03-2017, 12:26 AM
Um, that's the WEST bank. About the LEFT bank, you'd have to ask your average Parisien(ne).....
madpogue is offline
post #5 of 6 (permalink) Old 06-03-2017, 10:29 PM
Crankcase's Avatar
Kruegerk, Have you had any work done under the hood recently? It almost sounds like a connector that is not mating properly or maybe a severed wire. Let us know and we will try to suggest something that will solve your problem.
post #6 of 6 (permalink) Old 06-05-2017, 04:49 PM Thread Starter
Well took it to the dealer to have them diagnosis although the codes I scanned indicated IDM. Wanted to confirm before buying reman IDM. They verified it was the IDM. It's strange as there was no problem whatsoever the day before. Shut the truck down and went to fire it up the next day and that Bank went dead. Codes that I retrieved were P1316, P0605, P0282, P1272, P1274.
New IDM and everything is fine.
Kruegerk is offline
