Low vacuum warnign switch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-26-2017, 01:01 AM Thread Starter
I need a low vacuum warning switch. Has anyone repaired it?
There is no wanted section in the classifieds?????
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock wheels/tires & rebuilt 9.18
2 Donaldsons, 3" dp, ACs, T500, HV LPOP, Hydra w/PHP & Jeli, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, Aeromotive RR, Auber instruments, 140v IDM, KC 300X 63/70/84, RiffRaff bellowed up pipes, 6.0 IC, 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #2 of 5 (permalink) Old 05-28-2017, 11:06 AM
Terminator Nation
Re: Low vacuum warnign switch
Here's Sunrise Ford's online catalog page, their prices are usually cheaper than your local dealer. Your other choice would be a truck dismantling yard:
Buy 1996 Ford F-250 Parts | FordParts.com
old man dave is offline
post #3 of 5 (permalink) Old 05-28-2017, 11:16 PM Thread Starter
I called my local Ford dealer and they said its been discontinued and their is no stock. My local salvage yard had none. I also posted some adds in the forum wanted section, nothing yet. If nothing turns up? I can get an adjustable vacuum switch off of ebay.
Thanks for your help.
MeTo is offline
post #4 of 5 (permalink) Old 05-28-2017, 11:30 PM
alleged moderator
tjctransport's Avatar
they are no longer available anywhere.
the one in my old 92 shorted out when it was 6 months old and was disconnected.
it is still in the truck disconnected.
tom
tjctransport is offline
post #5 of 5 (permalink) Old 05-29-2017, 02:05 PM
410customs's Avatar
unplug it or do the adjustable, should be able to make the adjustable work no problem
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
