Fuel Overflowing From Rear Tank - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Robertl211
post #1 of 4 (permalink) Old 05-24-2017, 02:56 AM Thread Starter
CAT lover
Robertl211's Avatar
I have fuel overflowing from my rear tank while I have the front or rear tank selected. I assume I have trash in my selector valve. My question is if it is possible or effective to clean the valve? A new one is expensive!!!!
I think I probably have parts of my old tank suction filter thing stuck in the selector valve. When I had the tank dropped I tried to vacuum it all out but probably missed a few chunks.
96 F250 RCFB 4x4 7.3
03 Excursion Eddie Bauer 7.3
96 f350 CCLB Dually ZF5, custom flatbed, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
post #2 of 4 (permalink) Old 05-24-2017, 03:48 PM
Re: Fuel Overflowing From Rear Tank
Did you recently run that tank close to empty? Does your filter light come on?
JoeAS is offline
post #3 of 4 (permalink) Old 05-25-2017, 01:01 AM
I had problems with my rear filling up from the front tank (or it could have been the opposite, I don't remember). I replaced the tank switch on the dash and it didn't help so I replaced the selector valve. Guess what? That didn't help. A mechanic friend told me that my lines could be plugged. I ran some biocide through for a few tanks and it's worked well since. The next step would have been to blow the lines at the valve. I'm
mrvmax is offline
post #4 of 4 (permalink) Old 05-25-2017, 03:06 AM Thread Starter
CAT lover
Robertl211's Avatar
I converted to E fuel. Filter light comes on when my pressure is <30psi and it works. Have 2 full tanks. I'm 90% sure I have trash in the shuttle valve and it's sucking from 1 returning to both. Going to cycle it a few times tomorrow with a buddy by the valve to hear if it sounds right.
JoeAS likes this.
