E4OD randomly wont shift into 2nd - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-23-2017, 06:34 PM Thread Starter
Not completely stoopid
Floridacracker's Avatar
Garage
Hey guys back again sadly. So I went down to see my surgeon today about my hands a 200 mile drive round trip. I made it off the freeway thankfully on the way back home and from a stop my truck revs up to about 2k rpms and then wont shift to second,I can either back off then get back on it and it shifts or just hold it at about 2k and it will shift eventually. I tried to do some self trouble shooting. I pulled codes and there weren't any. I pulled the dipstick right after I shut the truck off when I got home and it had a slight burnt smell and the stick wasnt really full of fluid. Im gonna top it off and try again but low/bad fluid doesnt explain it shifting fine from 2-3-4-od. So Im really starting to think its rebuild time which means my truck might be sitting for quite a while. Im looking for any input I know you guys know your stuff so throw it at me. Thanks Everyone
Floridacracker is offline
post #2 of 3 (permalink) Old 05-23-2017, 11:07 PM
Re: E4OD randomly wont shift into 2nd
I have been doing a lot of research on these trans lately. Make sure all stop lights are working even the third one. Check vehicle speed sensor on rear diff for corrosion clean up contacts and dielectric grease it up. There is a lot of material about this on the google net.
JoeAS is offline
post #3 of 3 (permalink) Old 01-16-2019, 01:50 AM Thread Starter
Garage
Well I just saw this and I haven't done anything to it. I let her sit overnight then drove around the block manually shifting from 1-2-D and it started working again. Shes running fine now but the truck does lugg when I put it in reverse for a second then clears up. I think the trans is just dying a slow death and will just drive it till it dies then replace. I will check all of your recommendations though thank you.
