White smoke in morning. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-23-2017, 06:08 AM Thread Starter
1996 F350 5 speed
After truck has sat over night or Sat for a good while, it takes longer than normal to start truck. Once truck starts I am getting white smoke out of exhaust. Truck seems to not have much power for the first 5 or so miles of driving. Once truck warms up it drives just fine. And will start up just fine through out the day. Had buddy smell the smoke this morning when started cold. Said there was a hint of fuel smell. Just wondering what yall think it may be.
taylor17nelson is offline
post #2 of 4 (permalink) Old 05-23-2017, 01:24 PM
410customs's Avatar
Re: White smoke in morning.
I think its cold combustion chambers.
Does it smoke if you plug it in first?
What oil are you running?
Miles?
It may very well be worn poppet valves in your injectors. If it clears up when warm then it points to injectors. The 7.3 uses its crankcase oil as hydraulic fluid to make the 3000psi needed to inject the fuel. When the oil is cold the injectors have a harder time = unburnt fuel in the morning until the oil thins out and combustion chambers get up to operating temps
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #3 of 4 (permalink) Old 05-25-2017, 03:02 PM
Project Shamu
Lt.Dan's Avatar
Or it could just be glow plugs are weak. I'd start there.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #4 of 4 (permalink) Old 05-25-2017, 03:20 PM
^^^^^^^^^ or glow plug relay issue...can you hear the relay energize...should make a slight squealing sound when energized also check the posts for voltage with the key on
1996 F350 Crewcab lb 2wd auto, tommylift, now over 451k, 355k 3/31/15
1991 F250 Xtracab lb 2wd auto, sold again! Driveline and chassis is under a '65 F350 cab
1965 F100 styleside, power brakes, front discs, 390 all the goodies
2015 F250 CCSB 2wd gasser auto
2008 Mustang WIP, warriors in pink, wife's
2009 Focus, son's
aussamdad is offline
