So I Pressurized the Cooling System - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 21 (permalink) Old 05-22-2017, 02:58 PM Thread Starter
Diabolic1's Avatar
To try and find a leak. Ever since I replaced my waterpump, the expansion tank loses about 4-6oz of coolant a day. I thought it may be from air in the system but it's been to long now.
I've changed the oil and no water came out. I bypassed the heater core.....I'm still losing coolant. Yesterday I pressurized the system to 18 psi. In the first hour it dropped to 17psi, then 2 hours later it was to 16psi, and this morning, 9 hours later, it was at 12psi. Not a drop of coolant anywhere to be found.
What's going on here? No fuel in the coolant, no water in the oil, no water on the ground, no white smoke, no overheating, only loses 6psi over a 12 hour period. I've added 1/2 gallon of water over the past 2 weeks and 600 miles.
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 21 (permalink) Old 05-22-2017, 03:16 PM
Re: So I Pressurized the Cooling System
Did you pop the egr valve out and take a look if not dry could be egr cooler just a thought
Sent from my SAMSUNG-SM-N900A using Tapatalk
bmrrs is offline
post #3 of 21 (permalink) Old 05-22-2017, 03:29 PM Thread Starter
Diabolic1's Avatar
While driving I haven't seen the coolant pressure rise above 9 psi.
1997 CCSB, 7.3/E4OD
post #4 of 21 (permalink) Old 05-22-2017, 03:33 PM Thread Starter
Diabolic1's Avatar
These old 7.3's have an EGR?
1997 CCSB, 7.3/E4OD
post #5 of 21 (permalink) Old 05-22-2017, 03:37 PM
alleged moderator
tjctransport's Avatar
no egr or cooler on these engines.
two thoughts. did you test the pressure cap?
what does it do if you do not add anything?
my 88 diesel, and 04 gas job both will always loose a bit of coolant, but leave them alone and they will on a happy spot. the 88 is 1 inch low in the radiator. the 04 is 6 inches low in the tank. the 88 has held that level for close to 18 years, and the 04 for three years now.
tom
tjctransport is offline
post #6 of 21 (permalink) Old 05-22-2017, 03:57 PM Thread Starter
Diabolic1's Avatar
I bought a new cap at ford and tapped into the upper rubber hose on the Degas bottle. Installed a ball valve after the air filling to make sure it holds leak free.
1997 CCSB, 7.3/E4OD
post #7 of 21 (permalink) Old 05-22-2017, 03:59 PM Thread Starter
Diabolic1's Avatar
I've never left it alone to see how low it will get.
1997 CCSB, 7.3/E4OD
post #8 of 21 (permalink) Old 05-22-2017, 04:12 PM
410customs's Avatar
injector cup/head gasket leaking into combustion chamber and its being burned up?
Auto trans? Make sure its not going into the trans cooler inside the radiator!
Odd that it holds pressure so well and yo are still losing some...with no leaks
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #9 of 21 (permalink) Old 05-22-2017, 04:40 PM Thread Starter
Diabolic1's Avatar
I've never heard of a 7.3 losing a HG, esp one that gets babied like this one. If it was a HG leaking I would get some sort of pressure loss from the test, at least this has been my experience in the 12-15 head gasket failures I've had in my life. I suppose it could be the injector cups but it seems the truck should smoke at least a small puff after sitting overnight.
1997 CCSB, 7.3/E4OD
post #10 of 21 (permalink) Old 05-22-2017, 04:41 PM Thread Starter
Diabolic1's Avatar
I suppose it could be anything at this point. It's such a sloooooow leak, it may be impossible to find. I just dropped 4 bottles of UV dye in the coolant.
1997 CCSB, 7.3/E4OD
