Help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 05-16-2017, 03:32 PM Thread Starter
Foundordead's Avatar
Garage
Send a message via MSN to Foundordead
Help
New to the site. Have a 1995 7.3. Need help. Truck was running fine. Took off to bring wife to work pulled out of driveway made it 3/4 mile down road truck shut off like i had turned off the key.
This is what I have done so far.
Changed cps with known good one.
Checked hpop pressure 2650
changed icp with known good one.
Checked fuel pressure from combo pump,to heads 65 lb.
Did live data check
180 to 200 rpm while cranking
upto 2600lb hpop while cranking
did buzz test all checled good
Checked codes
P0606 came up faulty pcm
Pcm tested at ford was bad replaced
cheack all fuses all good
Checked relay operation all good.
Removed and cleaned
Wait to start is
still wont start
At last straw with this thing need help.about to semd it to the scrap yard.
Foundordead is offline
