Truck don't start with key - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 05-08-2017, 06:23 PM Thread Starter
I'm having more issues with my truck, I can get in the truck put the key in the switch turn the key and all the lights will turn on then turn it to crank it and it does nothing. But if the switch on and someone jumps the solenoid it will crank over fast.
whats my issue?
96powerstroker12 is offline
post #2 of 14 (permalink) Old 05-08-2017, 06:28 PM
Re: Truck don't start with key
Automatic or manual transmission?
Are you jumping the SOLENOID (which is ON the starter) or the RELAY (on the fender)?
madpogue is offline
post #3 of 14 (permalink) Old 05-08-2017, 07:29 PM Thread Starter
Auto and My bad its the Relay.
post #4 of 14 (permalink) Old 05-08-2017, 07:40 PM
Bugman's Avatar
Have you tried starting it in neutral?
Bugman is offline
post #5 of 14 (permalink) Old 05-08-2017, 07:57 PM
alleged moderator
tjctransport's Avatar
it could be the neutral safety switch is bad, or the ignition actuator in the steering column could be broken.
tom
tjctransport is offline
post #6 of 14 (permalink) Old 05-08-2017, 10:23 PM
Crankcase's Avatar
I had this same problem on my '06 350 about 4 months ago. I turned the ignition to ON, disconnected the lead in front of the HVAC box under the hood and touched it to the positive lead of the passenger side battery. It started right up and I replaced the ignition switch and that solved the problem.
Crankcase is offline
post #7 of 14 (permalink) Old 05-10-2017, 06:24 PM Thread Starter
I'll try the neutral start tonight. i hope its not something big in the column
post #8 of 14 (permalink) Old 05-10-2017, 07:29 PM
Native Texan
masakimm's Avatar
Garage
If its in the column it will be the ignition switch and they are not hard to change just a pain in the butt more then anything you can also put a test light on the relay and see if it gets the feed from the ignitoin switch. If not then either the park nuetral switch or the ignti9n switch on the column.
Upgrades:
masakimm is offline
post #9 of 14 (permalink) Old 05-10-2017, 09:00 PM
alleged moderator
broken actuator in the top of the column is a common problem with these trucks, much nor often than the actual switch going bad.
tom
post #10 of 14 (permalink) Old 05-10-2017, 09:12 PM
79jasper's Avatar
Apple's to oranges.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
