Cab and chassis tank straps - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-08-2017, 02:58 AM Thread Starter
obs addiction
JI97PSD's Avatar
Anyone know where i can get the rear tank straps and skid plate for my 97 cab and chassis truck?? The straps and and skid plate are rotted away to nothing. Tank is plastic not sure on the size
1997 F350 4x4 Auto trans SRW Reg cab
Mods: ts6 w/ TW tunes, BTS trans, idm mod, 3"dp 5" straight pipe, e-fuel. 17* t500, 238/100 rosewood hybrids, d66 turbo with ww2. Built from the crank up - sold
Couple of mostly stock obs 7.3 work trucks now
JI97PSD is offline
post #2 of 3 (permalink) Old 05-08-2017, 01:24 PM
79jasper's Avatar
Re: Cab and chassis tank straps
Should be about a 19 gallon.
Ask diesel_brad if/where he found them. I know he was looking.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #3 of 3 (permalink) Old 05-10-2017, 01:08 PM
I have a set, the front too. And tanks. I stripped everything and went to a 66 gallon custom. Pm me.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock wheels/tires & rebuilt 9.18
2 Donaldsons, 3" dp, ACs, T500, HV LPOP, Hydra w/PHP & Jeli, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, Aeromotive RR, Auber instruments, 140v IDM, KC 300X 63/70/84, RiffRaff bellowed up pipes, 6.0 IC, 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
