Another no start thread. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-05-2017, 01:33 AM Thread Starter
Powertoker's Avatar
Well, Im running into a no start issue after a long block rebuild. Everything is mostly new, Rebuilt injectors from rosewood diesel. Flashed PCM, High frequency IDM from Swamps diesel. Terminator 500 HPOP. Riffraff large HPOP res. MAHL Head gaskets, apr studs. new Motorcraft sensors. Please see video and give me some advice. Thanks
1995 1 ton CC 7.3. Purchased this truck running, had problems with it the following week after purchase. Had to overhaul the engine due to glow plugs lodged in the pistons.
A year later I've finally put it all back together:
https://youtu.be/E8tl881A2_M
Powertoker is offline
post #2 of 3 (permalink) Old 05-05-2017, 01:26 PM
410customs's Avatar
Re: Another no start thread.
Dang! Nice video
It sounds really healthy cranking at 160 rpm what a PITA!!
Start with basics
Is fuel bowl full do you have psi?
Hpop reservoir near top?
Did you fill the oil rails before cranking or let the starter handle it
Any smoke from tailpipe?
Does tach needle move?
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #3 of 3 (permalink) Old 05-05-2017, 06:36 PM
Hmm, just a guess, but unless that fuel pulse width setting is not the right one for our trucks, the fact that it remains zero tells me the IDM isn't commanding the injectors to fire.
Have you done a buzz test?
madpogue is offline
