Turbo Bolt Torque Spec - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 05-03-2017, 09:49 PM Thread Starter
I am in the process of replacing my turbo center section on my '97 powerstroke. I will also be changing out the pedestal to the deleted pedestal, the up-pipes and the exhaust manifold gaskets. If anyone could please supply me with the correct torq specs for all below, I would really appreciate it.
Exhaust manifold to block
New up-pipe to exhaust manifold
Turbo turbine housing bolts
Turbo exhaust housing bolts
Turbo pedestal to engine block
Turbo to turbo pedestal
Up-pipe collector manifold to turbo
Up-pipe to collector manifold
Turbo to down pipe
'97 F-350 is offline
post #2 of 2 (permalink) Old 05-04-2017, 09:31 AM
Terminator Nation
Re: Turbo Bolt Torque Spec
Here's a list of references from DieselInnovations, there is a listing for 7.3 torque specs. If the specific item is not listed, there is a list of M sized fastener torque specs.
Check the 7.3 Engine and Torque Spec listing.
old man dave is offline
