My gpr probs - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 (permalink) Old 05-03-2017, 02:05 AM Thread Starter
Bpettis419's Avatar
My gpr probs
My gpr isn't getting the signal to turn on. I really need some help here
Bpettis419 is offline
post #2 of 14 (permalink) Old 05-03-2017, 04:15 AM
Bugman's Avatar
Re: My gpr probs
Do you have power to it or is it not getting the ground from the PCM?
Fill out your signature so we know what you have as far as a truck.
Bugman is offline
post #3 of 14 (permalink) Old 05-03-2017, 12:46 PM Thread Starter
Bpettis419's Avatar
Re: My gpr probs
I think it's not getting power from the pcm. I took off the little leads and hooked it direct to power and ground on battery and I got power to the glow plug side
post #4 of 14 (permalink) Old 05-03-2017, 01:00 PM
Moderator
Sbluke55's Avatar
Re: My gpr probs
So the computer does not send power to the gpr. It actually connects the ground. So one of the small posts should have power all the time.
01 f-250, Standard
Sbluke55 is offline
post #5 of 14 (permalink) Old 05-03-2017, 01:12 PM Thread Starter
Bpettis419's Avatar
Re: My gpr probs
One of the big posts has power to it constantly but none of the other 3 are getting power. Key on or off. Is it true that I could run a toggle and turn the gpr on and off manually?
post #6 of 14 (permalink) Old 05-03-2017, 02:18 PM
Moderator
Sbluke55's Avatar
Re: My gpr probs
http://i82.photobucket.com/albums/j2...d69/Power3.jpg
From the diagram. The small wire only gets power in run and start. It's on the same fuse as the fuel bowl heater. I would check to see if you have power on the small red/Lt green wire with the key on.
Yes you can set up a toggle but why hack it up if you can fix it correctly.
01 f-250, Standard
Sbluke55 is offline
post #7 of 14 (permalink) Old 05-03-2017, 03:07 PM Thread Starter
Bpettis419's Avatar
Re: My gpr probs
That's the thing. I'm not getting any power on any wire with the key on except the constant power from the starter relay
post #8 of 14 (permalink) Old 05-03-2017, 03:18 PM
Bugman's Avatar
Re: My gpr probs
Check fuse #22 in the fuse box under the hood. This fuse powers the relay. If the fuse is good and you have 12 volts on it when the key is on then there is a wiring problem between the fuse and relay. If you don't have power to the fuse with the key on then there is a problem between the fuse and the ignition switch under the dash.
Do you get the wait to start light when you first turn the key on?
Bugman is offline
post #9 of 14 (permalink) Old 05-03-2017, 03:24 PM Thread Starter
Bpettis419's Avatar
Re: My gpr probs
Yea I get wts light
post #10 of 14 (permalink) Old 05-03-2017, 04:23 PM
Bugman's Avatar
Re: My gpr probs
Start tracing the wiring back from the relay to the fuse box. It sounds like either a wire is broken or a harness is unplugged.
Bugman is offline
