4x4 question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-02-2017, 10:07 PM Thread Starter
Christian123's Avatar
4x4 question
I know there has already been topics started on this, but my 1996 f350 4x4 is not engaging into four wheel drive, and it has automatic locking hubs. This past weekend I had a friend that was stuck call me to come pull him out, and I put it in 4 low and ended up getting stuck because the front wheels had no power, tried rolling back and forth and still not power in the front, I am thinking it's the auto hubs, but just wanted to make sure before I order a set of warn manual hubs.
Thanks,
Christian
Christian123 is offline
post #2 of 7 (permalink) Old 05-02-2017, 10:22 PM
Diabolic1's Avatar
Re: 4x4 question
Push button 4wd or shift lever.
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #3 of 7 (permalink) Old 05-02-2017, 11:30 PM
Re: 4x4 question
If push button is the light flashing on the 4x4 switch? If so pull the motor and clean the contacts had to do that many a time in my bronco.
gramps94 is offline
post #4 of 7 (permalink) Old 05-02-2017, 11:57 PM Thread Starter
Re: 4x4 question
It's the lever and yes lights come on, 4x4 and when in 4 low the "low range" light comes on
Sent from my iPad using Tapatalk
post #5 of 7 (permalink) Old 05-03-2017, 12:00 AM
Bugman's Avatar
Re: 4x4 question
It could also be the hubs. They are known for failing at the worst times. Or they fail and when you need them they don't work.
Bugman is offline
post #6 of 7 (permalink) Old 05-03-2017, 12:00 AM Thread Starter
Re: 4x4 question
It's the lever and yes lights come on, 4x4 and when in 4 low the "low range" light comes on, also I thought maybe transfer case, but when in 4x4 I made sure the front drive shaft wasnt turning, so tried to turn it and it wasn't so it is going into 4x4 and it's not the transfer case which is why I thought it has to be the Hubs
post #7 of 7 (permalink) Old 05-03-2017, 02:46 AM
Re: 4x4 question
You have to watch the underside of the truck while it's being run in 4x4. Watch for the front driveshaft and axle shafts to turn.
madpogue is offline
