1997 Ford 7.3 new glow plug relay and glow plugs - PowerStrokeNation : Ford Powerstroke Diesel Forum
 5Likes
post #1 of 23 (permalink) Old 05-01-2017, 01:09 AM Thread Starter
Wyattman's Avatar
My 1997 Ford 7.3L has new glow plugs and relay, but I have to turn the key of and on multiple times before it will start good. I hear the relay click on and it is on for about 5 seconds then clicks off. The light stay on for about 30 secs. It is around 40 degrees. Please help.
Wyattman is offline
post #2 of 23 (permalink) Old 05-01-2017, 01:57 AM
CAT lover
Robertl211's Avatar
Re: 1997 Ford 7.3 new glow plug relay and glow plugs
Need a new glow plug relay, you either wired it wrong, dirty connections, or she's flat out junk. There are better solutions to this just google 7.3 upgraded glow plug relay. My truck will not start until a while of white smoke and cranking in even 45 degrees out without the GPR working.
96 F250 RCFB 4x4 7.3
03 Excursion Eddie Bauer 7.3
96 f350 CCLB Dually ZF5, custom flatbed, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
post #3 of 23 (permalink) Old 05-01-2017, 01:57 AM
CAT lover
Robertl211's Avatar
Now my truck will start in zero degrees with one cycle of GPs
post #4 of 23 (permalink) Old 05-01-2017, 01:59 AM
CAT lover
Robertl211's Avatar
...and the GPRs you get new from advance, autozone, even napa, are junk. I think Dieselorings.com has a good one and riffraffdiesel.com has upgraded replacements as well. Sorry for the multi-post answer
post #5 of 23 (permalink) Old 05-01-2017, 03:15 AM Thread Starter
Wyattman's Avatar
No it is ok. Why are ones from those places junk?
Wyattman is offline
post #6 of 23 (permalink) Old 05-01-2017, 03:26 AM
Bugman's Avatar
Aftermarket glow plugs have a habit of swelling around their tips which leads to having to pull the heads to change them out.
The only ones that are recommended are Motorcraft/Breu ZD-11's.
Bugman is offline
post #7 of 23 (permalink) Old 05-01-2017, 03:28 AM Thread Starter
Wyattman's Avatar
Ok
Wyattman is offline
post #8 of 23 (permalink) Old 05-01-2017, 10:55 AM
alleged moderator
tjctransport's Avatar
all glow plug relays sold by auto parts stores are junk. go with the white rodgers/stancor 586 902 relay from diesel o-rings, Monster White-Rodgers Glow Plug Relay
and add a led to the output side to monitor when power is being sent to the plugs.
tom
tjctransport is offline
post #9 of 23 (permalink) Old 05-01-2017, 12:21 PM
Native Texan
masakimm's Avatar
Garage
Few years ago vender for my shop offered me smoking deal on a set of autolite glow plugs and so I ordered new gaskets and replaced them. With in 3 months 5 of the autolites plugs failed and took out the gaskets so new gasket and motorcraft plugs and been great till I started my rebuild last year. So yes go with better parts its not worth the trouble.
Upgrades:
masakimm is offline
post #10 of 23 (permalink) Old 05-01-2017, 08:20 PM
alleged moderator
yea, i will use ether to start my truck before putting anything besides motorcraft glow plugs in it.
tom
