1997 Fuel sending unit wiring diagram - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Patrick Feeley
post #1 of 4 (permalink) Old 04-28-2017, 07:01 AM Thread Starter
Hey guys, does anyone have the wiring diagram for a 97 fuel sending unit? The front tank sending unit OEM part number is F6TU-9275-CA. I'm installing a custom tank which comes with a sending unit, but the wires are different. The OEM sending unit has a Black, Red w/black stripe, Yellow, and Black w/red stripe. The new sending unit has a Red and a Black (neither is the ground, I will add that myself). I'm trying to make sense of it. I can't find a wiring diagram anywhere.
vegas_alex is offline
post #2 of 4 (permalink) Old 04-28-2017, 04:07 PM
Patrick Feeley's Avatar
Re: 1997 Fuel sending unit wiring diagram
Here is the diagram for a 1997 (from the EVTM). Cheers!
pcs0snq likes this.
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 4 (permalink) Old 05-01-2017, 03:55 PM
Paul Schultz 1996 F-350
Patrick Is the 1996 the same/ If not sure could you post that version. Thanks in advance
pcs0snq is offline
post #4 of 4 (permalink) Old 05-06-2017, 04:01 AM
Sorry, work got in the way (gone all week)! Here's the 1996 diagram. Cheers!
