1997 7.3 Does not seem to be making boost - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Lt.Dan
  • 1 Post By 410customs
post #1 of 8 (permalink) Old 04-25-2017, 02:53 AM Thread Starter
My 7.3 does not seem to be making boost, however....
When I remove the intake I can see the turbo wheel spinning, It is also solid and has no play to it so that seems fine (looks like it may have been rebuilt)
When I remove the Y pipe going into the motor it does seem like it is pushing air into where the intake would be.
There is no damage to the Y pipe or red hoses but when I hook up a boost gauge I get nothing. I had the boost gauge hooked up while driving around and it did no budge.
In the images you can see the test gauge is hooked up to where a boost gauge would go, but when I was actually testing for boost while driving it around I removed the hose with the T and directly connected the gauge to the motor.
Scott Rodriguez is offline
post #2 of 8 (permalink) Old 04-25-2017, 02:56 AM
edwester03's Avatar
Re: 1997 7.3 Does not seem to be making boost
Do you have the large o ring from the compressor to the y pipe? Mine didn't have one when I bought the truck. Made a big difference.
Sent from my LG-H810 using Tapatalk
edwester03 is offline
post #3 of 8 (permalink) Old 04-25-2017, 03:00 AM Thread Starter
yeup still there
post #4 of 8 (permalink) Old 04-25-2017, 11:36 AM
alleged moderator
tjctransport's Avatar
welcome to PSN. when you say it is not making boost, and you testing driving, or sitting and revving the engine?
you will see little to no boost unless the engine is under load.
hook up the gauge, and go for a ride. full throttle up a hill with a laod you should see around 15 lbs boost.
driving around town you should see 4-5 lbs boost.
tom
tjctransport is offline
post #5 of 8 (permalink) Old 04-26-2017, 04:25 AM
Project Shamu
Lt.Dan's Avatar
Could be a LOT of things making you not build boost. Another good way to check it is to create a boost leak detector, do some searching on the forum about it and it will help you find any leaks in the intake side. I guarantee you will find something. Hell I bet 65% of of people out there have some form of boost leak, whether big or small, and dont know it.
410customs likes this.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #6 of 8 (permalink) Old 04-26-2017, 01:53 PM
410customs's Avatar
I'm scared to try a boost leak test, kinda like going to the doctor knowing they will find something wrong with you
edwester03 likes this.
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #7 of 8 (permalink) Old 04-26-2017, 04:37 PM
There're whole other reasons why the doctor will always "find" something wrong with you...... (OT, I know.....)
madpogue is offline
post #8 of 8 (permalink) Old 05-20-2017, 04:11 AM
Shooter45's Avatar
Garage
I had the same issue last summer and didn't realize it until I was towing my 10k lb trailer and having problems with the passes. Hooked it up to a scanner and the MAP sensor was out, along with the air sensor. Turbo was spooling up but not getting the right air temperatures or elevation reading to engage. Replaced both sensors and it's up and running.
Run a scanner on it and you'll find out quickly if it's either of those sensors.
1996 F250 7.3
Automatic Transmission
4.10 gearing
160k miles
MBRP 4" exhaust
TS 6 Pos Chip
AFE 5R Big Honkin Air Filter
Original owner
"I come in peace, I didn't bring artillery. But I am pleading with you with tears in my eyes: If you f**k with me, I'll kill you all." Marine General James Mattis, to Iraqi tribal leaders.
Shooter45 is offline
