Sudden rough idle loss of power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 04-22-2017, 09:00 PM Thread Starter
CDavis90's Avatar
Garage
So i tried to google this first and all i can find is people with my issue saying yeah i have the same issue tying to figure it out.
Same day i refueled not sure if it has anything to do with my issue. My 97 started to idle rough just up and down 1 or 200rpm. and then today it also shudders the truck on acceleration sounds terrible then somewhat levels out with higher rpms, loss of power lots of grey smoke and black. The truck came with a cheap dp tuner i plan on removing and has been getting about 12mpg at best. I have not had a diesel before and have owned this one a few months. The fuel filter is new and i changed the oil. From my last post the general though was my engine is from a 99-03. This truck has also been a bear to start if it has not been plugged in.
Being new to diesel and from what other people think im assuming my injectors are bad and the glow plugs.
CDavis90 is offline
post #2 of 18 (permalink) Old 04-22-2017, 09:03 PM
c-case7.3's Avatar
Re: Sudden rough idle loss of power
Is the check engine light on?
c-case7.3 is offline
post #3 of 18 (permalink) Old 04-22-2017, 09:07 PM
Bugman's Avatar
Pull the tuner first and see what happens. Also the wiring that goes through the valve cover gaskets will also go bad over time and you'll end up with burnt and shorted pins in them. You can unplug them and see what the pins look like. There are 2 on each valve cover gasket.
Bugman is offline
post #4 of 18 (permalink) Old 04-22-2017, 09:12 PM
c-case7.3's Avatar
Yeah that's what happened to mine but the check engine light was on and didn't have enough power to go over 40mph the ground wire that wraps around the wires ate into them.
post #5 of 18 (permalink) Old 04-22-2017, 09:27 PM Thread Starter
CDavis90's Avatar
Garage
There is no engine light on. I will look into the wiring harness.
CDavis90 is offline
post #6 of 18 (permalink) Old 04-23-2017, 04:00 AM
new to the internet
turbo_loco's Avatar
what kind of smoke is more common? black or grey/white? sounds like a air-fuel mixture problem for sure, but it could be secondary to an electrical problem. how many times do you have to turn over before it will start?
id check the GP relay first then feel each manifold for a cold spot. then check the wires from there.
1996 F350 7.3
2004 F250 6.0
turbo_loco is offline
post #7 of 18 (permalink) Old 04-24-2017, 01:45 AM Thread Starter
CDavis90's Avatar
Garage
untill its warm its grey unless your accelerating then its all black. if its plugged in for a while it starts right up if not its a lot.
CDavis90 is offline
post #8 of 18 (permalink) Old 04-24-2017, 05:27 AM Thread Starter
CDavis90's Avatar
Garage
just for curiosity's sake i used an inferred thermometer on the exhaust and the number one cylinder was much colder.
CDavis90 is offline
post #9 of 18 (permalink) Old 04-24-2017, 03:18 PM
drick1lsu's Avatar
Garage
how many miles on the truck? if previous owner didn't maintenance it well, you could have a stiction issue. That would explain the change in exhaust color once warm
1995 F-250 single cab. 4"lift and level. D60 Swap. 3"mbrp down pipe to 4"muffler exhaust. S&B intake. Swamps tuned T6. Baby Swamps Injectors. Swamps HVHF IDM. Adrenaline HPOP. 1.0 AR Exhaust, Wicked Wheel, e99 spider w/ Superduty Intercooler. Sinister Diesel Coolant Filter. Amsoil Secondary Oil Filter. Mickey T 16x9 and 35 MT
drick1lsu is offline
post #10 of 18 (permalink) Old 04-24-2017, 10:51 PM
new to the internet
turbo_loco's Avatar
Originally Posted by CDavis90 View Post
i used an inferred thermometer..and the number one cylinder was much colder.
looks like youve got the geography down, i can agree with previous owner neglect but sudden onset is interesting. whats the weather like or what part of Utah are in? having to plug your truck in if its not that cold might be the plugs but the black smoke sounds more injector related.
1996 F350 7.3
2004 F250 6.0
