Pull codes on 97 f450 psd? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-18-2017, 09:21 PM Thread Starter
Hey guys. Is there a way to pull codes without a scanner. Like jumping out a connectors and cel flashes? Don't have access to an ae scanner
Skatemoresonnn is offline
post #2 of 10 (permalink) Old 04-19-2017, 01:27 AM
Patrick Feeley's Avatar
Re: Pull codes on 97 f450 psd?
No you can't jump pins in the connector. Some of the plug-n tuners can read codes on these. I think some of the ScanGauge products will work, although I'm not sure which models will work on a 7.3 PSD (hopefully someone will chime in on this). Cheers!
Patrick Feeley is offline
post #3 of 10 (permalink) Old 04-19-2017, 04:33 AM
Bugman's Avatar
Or try to find a vin locked Superchips 1705 and use it for a code reader.
Bugman is offline
post #4 of 10 (permalink) Old 04-19-2017, 01:20 PM
Moderator
Sbluke55's Avatar
Last I knew that the only years the scan gauge will work is 02-03.
Google superduty diagnosis on the cheap. I know you don't have a superduty but it works the same. I use forscan all the time.
01 f-250, Standard
Sbluke55 is offline
post #5 of 10 (permalink) Old 04-19-2017, 01:45 PM
410customs's Avatar
stupid IOS I want to try Forscan why cant apple get their sh*t together
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #6 of 10 (permalink) Old 04-19-2017, 02:11 PM
Moderator
Sbluke55's Avatar
Used laptops are cheap. I got a $50 laptop for shop use.
01 f-250, Standard
Sbluke55 is offline
post #7 of 10 (permalink) Old 04-19-2017, 02:26 PM
410customs's Avatar
Do you use bluetooth or a cable?
Might be time to snag up one of my dad's old PC laptops and see if I can get it up and running
21.9 liter family
post #8 of 10 (permalink) Old 04-19-2017, 02:31 PM
Moderator
Sbluke55's Avatar
I use my Bluetooth dongle. It's a pain in the butt though. I have to un pair and re pair it every time I use it. Only reason I still use it is I'm cheap and don't want to buy the usb. Plus I already had the dongle.
01 f-250, Standard
Sbluke55 is offline
post #9 of 10 (permalink) Old 04-20-2017, 12:15 AM
csp
I use Forscan on a laptop as well, but with the OBD2 to USB cable. $20 at Amazon IIRC.
The Superchips programmer will only pull trouble codes. Forscan allows contribution tests, IPR values, etc. It's very helpful and free software for laptop use.
csp is offline
post #10 of 10 (permalink) Old 04-24-2017, 03:39 PM
drick1lsu's Avatar
Garage
I use the car gauge pro app ($9+/-) and an Amazon bluetooth dongle ($15+/-) with an old tablet that was given to me......I can pull codes, perform injector buzz tests, etc. There's an option for a contribution test, but my curiousity hasn't peaked enough to try it.
1995 F-250 single cab. 4"lift and level. D60 Swap. 3"mbrp down pipe to 4"muffler exhaust. S&B intake. Swamps tuned T6. Baby Swamps Injectors. Swamps HVHF IDM. Adrenaline HPOP. 1.0 AR Exhaust, Wicked Wheel, e99 spider w/ Superduty Intercooler. Sinister Diesel Coolant Filter. Amsoil Secondary Oil Filter. Mickey T 16x9 and 35 MT
drick1lsu is offline
