Zf42 fluid type - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-18-2017, 08:20 PM Thread Starter
Zf42 fluid type
Got a 97 f250 that was a automatic and I just swapped it over to a manual. Donor transmission was a zf42 out of a 93 7.3idi. Everything went great. Truck runs like it rolled off the assembly line as a manual. I get confused when automatic transmission fluid is talked about. The book calls for synthetic mercon. I put castrol mercon v in it. Is this synthetic? I'm also getting alot of gear roll over noise. I did put a single mass flywheel on it.
Sent from my SM-G900V using Tapatalk
tn_archer is offline
post #2 of 5 (permalink) Old 04-18-2017, 08:39 PM
Re: Zf42 fluid type
If it doesn't say synthetic, it's not. And yes, ZF requires synthetic in this transmission when it's behind a Powerstroke. Synth might reduce the rollover noise, but some fellas just overfill the tranny some by filling from the shifter opening.
madpogue is offline
post #3 of 5 (permalink) Old 04-18-2017, 09:17 PM
410customs's Avatar
Re: Zf42 fluid type
all merc V is synthetic no matter who makes it
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #4 of 5 (permalink) Old 04-18-2017, 10:00 PM
Native Texan
masakimm's Avatar
Garage
Re: Zf42 fluid type
Yeah mercon.v is synthetic and when I put it in my s5-42 that was in My 95 f350 I got alot of rollover noise with the single mass flywheel.
Upgrades:
masakimm is offline
post #5 of 5 (permalink) Old 04-20-2017, 07:22 AM
Re: Zf42 fluid type
I use Redline MTF 4 quarts through the shifter top is easiest. Single mass will create more rollover. Congrats on the conversion.
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37 Toyo R/Ts intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is online now
