Injector oil deflector - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-17-2017, 03:46 PM Thread Starter
So i just installed some new to me injectors and truck idles better and runs decent. I've been chasing a blueish smoke from the tailpipe since I have got the truck. When I took the VC off to check the wiring i noticed one of the injectors not flowing as much oil from the spout as the others. Could I have torn an o ring and its dumping oil into the exhaust? Or does that usually mean the injector is bad? I am hoping I just tore an o ring and the oil is leaking into the combustion chamber and that is also my oil issue. Does this logic sound right? Or just get another injector?
96 F-250 4x4 Crew Cab
papa87 is offline
post #2 of 4 (permalink) Old 04-18-2017, 12:11 AM
410customs's Avatar
Re: Injector oil deflector
could easily be O ring issue just as you suspect, pull injector and find out
oil can go into combustion chamber too and get burned up
Oil in exhaust often is bad turbo seals
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #3 of 4 (permalink) Old 04-20-2017, 03:35 PM
97_psd's Avatar
I agree with 410customs... Also, if an injector was not seated properly or an o-ring is torn, you will have some blue smoke.
1997 F250HD
Swamps 160/100%'s
Adrenaline HPOP
Comp Cams 910 valve springs
Smith Brothers push rods
ARP studs
WW2/1.0 A/R TP38
Dieselsite built 4r100
Swamps tunes
Irate's efuel w/ Fuelab 41402
97_psd is offline
post #4 of 4 (permalink) Old 04-27-2017, 06:53 AM
it's an easy enough fix to replace or fix the o ring and see whether the issue is solved or not . Perhaps you could try that out first and see whether the issue is resolved and then we can work it out from there. I mean from the looks of it, right now the problem is one of the other, so you might as well see what you can fix first and then move forward with the results. Hopefully everything will be ok after that first fix. Good luck.
http://financesmarter.com.au/vehicle/cars/ford/
webbrowan is offline
