Parts Store PCM - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-13-2017, 12:54 AM Thread Starter
Diabolic1's Avatar
Parts Store PCM
I'm getting a P0605 code along with some hard and quick shifting. Think the PCM is toast. Ebay has them from $300-$600 but the local parts store has them for $125. Is there something I'm missing here? Anyone have one they want to sell?
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 10 (permalink) Old 04-13-2017, 01:15 AM
Patrick Feeley's Avatar
Re: Parts Store PCM
I got one at RockAuto for $115 about 5 years ago and it was just fine. If it is no good, return it. Cheers!
Patrick Feeley is offline
post #3 of 10 (permalink) Old 04-13-2017, 01:40 AM Thread Starter
Diabolic1's Avatar
Re: Parts Store PCM
So turns out it isn't available at the parts store. Will any auto trans pcm from a 95-97 7.3 work?
1997 CCSB, 7.3/E4OD
post #4 of 10 (permalink) Old 04-13-2017, 07:08 AM
Terminator Nation
Re: Parts Store PCM
Generally yes, but there are minor differences. Check your pms.
old man dave is offline
post #5 of 10 (permalink) Old 04-13-2017, 07:16 AM
Terminator Nation
Re: Parts Store PCM
Here's some info on P0605: It doesn't mean its always the PCM.
https://www.engine-codes.com/p0605_ford.html
post #6 of 10 (permalink) Old 04-13-2017, 12:06 PM
Re: Parts Store PCM
Diabolic1, I tried to send you a PM in response to yours. As I have not yet reached a post count of 15 the system will not let me. Call this number between 8-5 Eastern and I will give you the answer to the question you asked me. T&W Services 478-484-5820
Battlewagon is offline
post #7 of 10 (permalink) Old 04-13-2017, 01:39 PM Thread Starter
Diabolic1's Avatar
Re: Parts Store PCM
Where is the PCM ground located? Is there a PCM power relay behind the kick panel? I'm familiar with the gas trucks but. It the diesels.
1997 CCSB, 7.3/E4OD
post #8 of 10 (permalink) Old 04-13-2017, 04:09 PM Thread Starter
Diabolic1's Avatar
Re: Parts Store PCM
I don't think my problem is coming from a hot wire shorting out or it would most likely blow a fuse. I'm thinking bad ground, bad PCM, or a problem with the 6 Pos Chip. If I clear the code with my Snap On Brick then she's fine for a while. All off a sudden it won't come off idle and when it decides to move the cel light comes on, OD light flashes, and it goes into limp mode.
I already swapped out the PCM relay and I'm about to pull the chip. Can anyone tell me where the PCM ground is located?
1997 CCSB, 7.3/E4OD
post #9 of 10 (permalink) Old 04-13-2017, 05:17 PM
Re: Parts Store PCM
Chip is something that would have been worth mentioning in post 1 (and NO, signatures don't count...). REMOVE the chip and see if the problem persists or the code still appears. If not, the chip is where you want to focus.
madpogue is offline
post #10 of 10 (permalink) Old 04-13-2017, 05:21 PM Thread Starter
Diabolic1's Avatar
Re: Parts Store PCM
I just removed the chip and I'm about to go for a long drive to see if the cel light will come back on. I'll report back.
1997 CCSB, 7.3/E4OD
