94 powerstroke loss of power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 04-08-2017, 03:10 PM Thread Starter
martins96's Avatar
I lose power than gain powe back after the key is cycled i put the idm from my 96 and new wiring under the valve covers
martins96 is offline
post #2 of 15 (permalink) Old 04-08-2017, 03:25 PM
410customs's Avatar
Re: 94 powerstroke loss of power
some more info would sure be nice
Thats a good start
Miles? History of the problem? When do you notice it (constant or intermittent), etc
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #3 of 15 (permalink) Old 04-08-2017, 03:30 PM Thread Starter
martins96's Avatar
440000 miles and it's intermittent longer you drive it the more intermittent it is no cel just a loss of power until the key is cycled this is a new problem
post #4 of 15 (permalink) Old 04-08-2017, 04:26 PM
Clarify "loss of power". Does it stall? Or does it just fail to provide the usual amount of horsepower? Does this happen while going down the road?
Automatic or manual transmission?
madpogue is offline
post #5 of 15 (permalink) Old 04-08-2017, 04:37 PM Thread Starter
martins96's Avatar
It's a manual and I lose power al together it will barley go up a slight hill and gets really quiet sometimes it will stall out
post #6 of 15 (permalink) Old 04-08-2017, 04:47 PM
When this happens, have you tried pulling over and seeing if the engine responds to the accelerator while standing still? (Before restarting the engine, that is.)
madpogue is offline
post #7 of 15 (permalink) Old 04-08-2017, 05:02 PM Thread Starter
martins96's Avatar
Yes it will only go to around 2000 rpm feels like half throttle
post #8 of 15 (permalink) Old 04-08-2017, 05:37 PM
But it does respond to some extent. Well, that eliminates one possibility I had, that it was the pedal, either the position sensor or the idle switch.
madpogue is offline
post #9 of 15 (permalink) Old 04-08-2017, 10:21 PM
1997 powerstroke
chedda's Avatar
Garage
Get it coded scanned.
1997 7.3 Cali ECLB, 210k, 3in Diamond Eye Down Pipe, aFe intake, ts tuner chip, glowshift gauges
Just trying to keep it running
chedda is offline
post #10 of 15 (permalink) Old 04-09-2017, 08:18 PM
Maybe starving for fuel I know some of the newer models have a screen in the tank that gets restricted with dirt something to check
Sent from my SAMSUNG-SM-N900A using Tapatalk
bmrrs is offline
