1997 7.3 PSD Barometric Pressure Reading - Rough Idle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-03-2017, 12:59 AM Thread Starter
MattieS's Avatar
Hi,
I'm having an issue with rough idle on my 1997 7.3 PSD. It's not a violent rough idle, and the engine sounds normal but it vibrates the truck a bit. I've checked codes with an OBDII scan tool and FORscan, no codes. I've checked several instrument readings, and thought the barometric pressure reading might be suspect. I'm in Vancouver, right beside the ocean so I would expect 101 kPa however the reading is 64.3 kPa. The truck has the external BARO sensor under the dash, so I disconnected it thinking the PCM would default to 100 kPa but instead defaulted to 60 kPa. Out of curiosity I looked at the EBP sensor reading with the engine off and it read 100.2 kPa which is about right. I recently went up north to Prince George (600 Meter elevation) and the BARO pressure reading dropped from 64 to 60.3 kPa, so it is measuring pressure but appears to be off by about 40 kPa. I'm wondering if the previous owner could have programmed an offset factor somehow seeing as it defaults to 60 kPa? Or maybe the PCM is bad. Just dawned on my, it has a TS 6 position chip, so maybe that could change the PCM readings? It was set to +70HP when I read all of the parameters, I will go check it again on the stock setting.
From what I've read the PCM will retard the injection timing according to the BARO pressure, and I would imagine with would decrease the HPOP pressure for a leaner air fuel mixture (I'm just guessing here, might be way off). I have an analogue gauge on my dash for the HPOP pressure, and on the highway in 5th gear doing 100 km/h when I step on it the pressure only goes up to 2750 kPa and it just feels like it's lacking power. Still lots of power at the bottom end though.
The truck has 250,000 km on it, and the engine was replaced by the last owner which came out of a California 97 E350 with ~70,000 km. It seems to be in good shape.. Starts fast, doesn't smoke, doesn't burn oil. Just seems to me like the timing is slightly off.
Any opinions / tips would be much appreciated. Thanks!
MattieS is offline
post #2 of 6 (permalink) Old 04-03-2017, 01:05 AM
79jasper's Avatar
Re: 1997 7.3 PSD Barometric Pressure Reading - Rough Idle
Typically doing sensor readings, you should verify with stock settings/no chip.
Also something isn't right here. You're giving us metric readings... but... You're truck wouldn't hardly be running with 2750kpa icp. That's just under 400 psi.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #3 of 6 (permalink) Old 04-03-2017, 02:13 AM Thread Starter
MattieS's Avatar
Ok thanks, I will check the readings in stock mode tomorrow. Do you know if I have to uninstall the chip, or can I simply switch it to the stock setting? Sorry I was stuck in Metric mode, I meant 2750 PSI (18960 kPa).
MattieS is offline
post #4 of 6 (permalink) Old 04-03-2017, 02:43 AM
79jasper's Avatar
That's not too terrible, Iirc.
I guess you can try the stock tune first to see if it reads right. If it still doesn't, try with it removed.
79jasper is offline
post #5 of 6 (permalink) Old 04-03-2017, 02:09 PM
Never assume that "stock" setting really means stock. If you don't want to have to wonder if the chip is a factor, remove it. That's always step 1 anyway.
madpogue is offline
post #6 of 6 (permalink) Old 04-03-2017, 06:40 PM Thread Starter
MattieS's Avatar
Alright, I checked on the stock setting.. No change. I'm going to take the chip out after work. I know I need to disconnect the batteries, but other than that can I simply disconnect the chip from the PCM and fire it back up?
Thanks.
MattieS is offline
