e4od not locking up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-25-2017, 01:59 AM Thread Starter
e4od not locking up
Hey guys brand new here, hoping someone can help out i recently picked up a 96 3/4 4wd with e4od. well it recently went into limp mode. shifts fine through the gears up to od but never locks up. So i had the codes read and it came up, "high temp" and slipping. well after some research i founf the lockup switch trick. i tried that and still get nothing. Is it possible to replace just the tcc solenoid or clutch. I have an idea of hows transmisions work but not an exact understanding.
icetrey3 is offline
post #2 of 12 (permalink) Old 03-25-2017, 02:18 AM
Master BS'er
jamiesaun's Avatar
Re: e4od not locking up
Tcc solenoid, yes that's an easy job, it'll be somewhere in the valve body underneath the pan.
Tc clutch? No. That requires a new torque converter.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #3 of 12 (permalink) Old 03-25-2017, 03:24 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
If the solenoid were the problem you should get a code for the solenoid. Most likely the torque converter is the problem..
Take the inspection cover off of the front of the bellhousing. Does the front face of the converter look discolored? They can get blued from heat from a slipping clutch.
Mark
Mark Kovalsky is offline
post #4 of 12 (permalink) Old 03-26-2017, 03:30 PM Thread Starter
I'll check it the tc. Would it be worth it or practical to just replace the valve body?
icetrey3 is offline
post #5 of 12 (permalink) Old 03-26-2017, 03:56 PM
Master BS'er
jamiesaun's Avatar
No way Jose. I think Mark is entirely correct, though I don't know how quick these older trucks would be to throw a code, with all the miles on this thing, you can be pretty confident the converter clutch has worn.
So basically, a new converter is probably what you're looking at. Again, because of the mileage, a full rebuild would be a good idea, but a new converter should fix this problem.
Brother James
post #6 of 12 (permalink) Old 03-26-2017, 07:50 PM
Diabolic1's Avatar
Any chance you have a brake light stuck on?
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #7 of 12 (permalink) Old 03-27-2017, 03:22 AM
This can also happen if the third brake light isn't working.
Mark
post #8 of 12 (permalink) Old 03-27-2017, 03:34 AM
Master BS'er
jamiesaun's Avatar
Not if it's slipping. A brake switch would keep it from locking up, but it wouldn't cause slippage. Slipping is either a pressure problem or a worn disc. The high temps are another clue.
Brother James
post #9 of 12 (permalink) Old 03-28-2017, 12:20 AM Thread Starter
I know my lower brake lights work. The truck does have 212k previous owner said it had tranny work. So I was planning on a reman trans and beefier tc to handle a little extra power and towing. Correct me if I'm wrong but there is no easy way to get a 5 spd auto in these is there?
icetrey3 is offline
post #10 of 12 (permalink) Old 03-28-2017, 12:58 AM
Diabolic1's Avatar
Not without a way to control the transmission. Just throw a C6 in there and a gear vendors OD.
1997 CCSB, 7.3/E4OD
