Manual to Automatic - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 03-23-2017, 02:30 AM Thread Starter
Garage
Manual to Automatic
Alright I know I am going to get #### for this. But my Manual trans needs to be rebuilt. I wouldn't mind switching to an automatic. I can get an automatic trans for my truck cheaper than I can get a manual. What I am wondering is what all do I need to do to convert it over? So far the only thing I have heard so for is swap PCM's? Also any drive shaft modification? It's a 1997 F350 7.3l.
Kershaw5983 is offline
post #2 of 11 (permalink) Old 03-23-2017, 02:42 AM
Native Texan
masakimm's Avatar
Garage
Re: Manual to Automatic
Well As i'm doing this on my project you will need trans pcm wiring harness for trans cross member for trans driveshaft for your truck only need front half the rear half is the same. I'm using an after market controller you can find more in my project log listed in my Signature.
Upgrades:
masakimm is offline
post #3 of 11 (permalink) Old 03-23-2017, 02:47 AM
79jasper's Avatar
Aftermarket controller/harness is the way I would go.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #4 of 11 (permalink) Old 03-23-2017, 02:58 AM
Native Texan
masakimm's Avatar
Garage
And you will need a new steering column for an auto or fab one like I'm doing.
This Is controller I'm using.
also need to either have a radiator with a cooler or an aftermarket cooler
Upgrades:
masakimm is offline
post #5 of 11 (permalink) Old 03-23-2017, 03:33 AM Thread Starter
Garage
I tried private messaging you if you could email me that would be great. [email protected]
post #6 of 11 (permalink) Old 03-23-2017, 01:57 PM Thread Starter
Garage
Do you still have your ZF5 transmission or have you sold it already?
post #7 of 11 (permalink) Old 03-23-2017, 02:24 PM
Native Texan
masakimm's Avatar
Garage
I do have my zf its a 42 but its tired it will run but it had the typical roll over noise and the 2-3 sync and 3-4 sync going up shift was fine just couldnt down shift into second. So it needstlc i know at one point bearings were replaced but syncs were not. But it has had a long life at 350000 miles.
Upgrades:
masakimm is offline
post #8 of 11 (permalink) Old 03-23-2017, 02:40 PM Thread Starter
Garage
I dont know if mine is a 42 or a 47. I dont have the tag on the transmission. is yours 4x4?
post #9 of 11 (permalink) Old 03-23-2017, 02:53 PM
Native Texan
masakimm's Avatar
Garage
No mines a 4x2 your is proably a 47 if i had been able to keep a manual i was going to find a 47 to replace the 42.
Upgrades:
masakimm is offline
post #10 of 11 (permalink) Old 03-23-2017, 03:11 PM Thread Starter
Garage
Damn its really hard for find a zf5 4x4 for less than $2500
