Cam position sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 (permalink) Old 03-22-2017, 06:40 PM Thread Starter
Cam position sensor
Are there any early signs a cps makes when it's going out? Truck has been acting sorta funny the past day or two. The rpm stays at ~1400 when in 3rd and doesn't move unless it comes to a stop or goes into 4th. Not sure if this is cps or not.
1995f250 is offline
post #2 of 11 (permalink) Old 03-22-2017, 11:48 PM
Re: Cam position sensor
Usually not. Sometimes they fail to the point where the truck will not run, other times they fail to the point where the idle is not right. They can also have intermittent issues. Basically, it is a toss up. If you are questioning the CPS, just go pick another one up from Ford for $25. It is best to have a spare anyway.
post #3 of 11 (permalink) Old 03-22-2017, 11:54 PM Thread Starter
What would cause the issues I'm having?
1995f250 is offline
post #4 of 11 (permalink) Old 03-23-2017, 12:01 AM
Native Texan
masakimm's Avatar
Garage
Yeah what Justin said and don't get one from parts store I got in a hurry and didn't want to wait till next day so got one and truck ran great until I set the cruise then it would have intermittent misses but could run same speed with out cruise and no miss so get an oem from Ford its worth it.
1995f250 likes this.
Upgrades:
masakimm is offline
post #5 of 11 (permalink) Old 03-23-2017, 04:59 PM
So no matter how hard you push the pedal, the RPM's will not go above 1400? If that is the case, I would be thinking there was an issue with a pedal assembly or something. However, like I said, cam sensors are cheap and you should have a spare anyway, so go pick one up and try it.
post #6 of 11 (permalink) Old 03-23-2017, 05:02 PM Thread Starter
The trucks rpm won't move unless I press the brake or make it shift to 4th or let it downshift. It's only in 3rd, previously had the truck go through test with auto enginuity? I know it's spelt wrong and a test wouldn't go through because it detected the pedal was pressed when it wasn't.
1995f250 is offline
post #7 of 11 (permalink) Old 03-23-2017, 05:06 PM
Okay, then I would suspect the accelerator pedal assembly has got an issue. You should be able to watch this on a scan tool. You can watch the percentage of pedal. If it is not going up when you press the pedal further, you have confirmed the problem.
post #8 of 11 (permalink) Old 03-23-2017, 06:29 PM
^^^^ This - Set AE to Live Data Grid, and set one of the data displays to "Accelerator Pedal Position %". I *think* that's the name; I know you have to select the one beginning with "Accelerator" and not "Throttle". You can do this key-on engine-off. Once you have it set, work the pedal and see what range it goes through.
madpogue is offline
post #9 of 11 (permalink) Old 03-23-2017, 06:35 PM Thread Starter
I don't have it AE and don't have the funds to buy it or a computer to install it on. KBMKVIII helped me get the truck back up and running good. Thankful for his help.
1995f250 is offline
post #10 of 11 (permalink) Old 03-23-2017, 09:42 PM
The only easy way to diagnose the pedal is with an OBDII scan tool that can monitor that PID. Does not necessarily have to be AE, but you will need something that can do the live data on these 7.3L's. Without a scan tool, you are just shooting in the dark when it comes to diagnosing and fixing things.
