Zf5 Transmission - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Sbluke55
  • 1 Post By madpogue
post #1 of 6 (permalink) Old 03-22-2017, 01:54 PM Thread Starter
Garage
Zf5 Transmission
Alright so I have a 1997 F350 7.3l OBS SCLB having lots of transmission noise. Clutch is pretty new. So I think I have ruled it out to bearings inside the transmission. My question what is a good quality rebuild kit that wont cost over $600
Kershaw5983 is offline
post #2 of 6 (permalink) Old 03-22-2017, 02:01 PM
Moderator
Sbluke55's Avatar
Re: Zf5 Transmission
When do you have the noise?
If its just in neutral or creeping around the parking lot. You have gear roll over. You can try syncro mesh or redline atf.
410customs likes this.
01 f-250, Standard
Sbluke55 is offline
post #3 of 6 (permalink) Old 03-22-2017, 02:04 PM
410customs's Avatar
Should I be running a synchromesh atf in my zf5????
Synchromesh ATF is designed for gearboxes with high pressure gears and it "climbs" up gears very well.
Currently mine is filled with Mercon V
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #4 of 6 (permalink) Old 03-22-2017, 02:28 PM
Moderator
Sbluke55's Avatar
You dont need to run sycromesh. It just helps with gear roll over noise.
01 f-250, Standard
Sbluke55 is offline
post #5 of 6 (permalink) Old 03-22-2017, 02:33 PM
To the OP, when you replaced the clutch, did you also switch from a dual-mass to a single-mass flywheel? Are you running SYNTHETIC ATF?
Sbluke55 likes this.
madpogue is offline
post #6 of 6 (permalink) Old 03-23-2017, 12:03 AM Thread Starter
Garage
The clutch was replaced right before I bought it. And I changed the fluid once i got it to synthetic atf. Sitting in neutral it does it in gear setting still it does it and in gear and driving it does it the only time it quietness up is when you give her a little fuel or even hard acceleration it goes away until you let off then the bearings are noisy as hell
