P1271-8 codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-22-2017, 01:45 AM Thread Starter
P1271-8 codes
Just did a buzz test with my phone and the car gauge pro app. Buzz test sounded good but then got the p127 codes on all 8 cylinders? Truck runs decent when warm. It does have a miss when cold but goes away. Is something crazy wrong??
96 f250
96 F-250 4x4 Crew Cab
papa87 is offline
post #2 of 5 (permalink) Old 03-22-2017, 03:01 AM
Patrick Feeley's Avatar
Re: P1271-8 codes
In case you are so inclined, here are the pinpoint tests for the P127x DTCs. It will at least let you know where to start looking if you study them. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 5 (permalink) Old 03-22-2017, 03:09 AM Thread Starter
Re: P1271-8 codes
Thank you for the info. Are the AA and AB injectors fairly similar? I was really hoping that the reader couldn't really read the injectors and just threw a code.
papa87 is offline
post #4 of 5 (permalink) Old 03-23-2017, 02:12 AM
Re: P1271-8 codes
For a buzz test, the reader won't care whether the injectors are AA or AB as the solenoids are the same. You should have AA injectors unless you have a late-96 Cali truck. Cheers!
post #5 of 5 (permalink) Old 03-23-2017, 02:18 AM Thread Starter
Re: P1271-8 codes
Yep AA they are. Just the codes are concerning since it was all 8. Hoping it was just the reader not the injectors.
papa87 is offline
