Obs axle differences - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-22-2017, 12:18 AM Thread Starter
I am swapping from 4.1 to 3.55 in my 96 and found one from a 1990. Will this work for my swap looking at parts only thing I found different between two is brake cylinders with late being 1.25 bore vs 1. Also anyone know if later brake cylinders will actually work both on my 96 are new.
cory99 is offline
post #2 of 4 (permalink) Old 03-22-2017, 12:33 AM
alleged moderator
tjctransport's Avatar
Re: Obs axle differences
same axle. unbolt the 96 brakes and bolt them on to the 90 axle.
tom
tjctransport is offline
post #3 of 4 (permalink) Old 03-22-2017, 02:47 AM Thread Starter
Thanks that's what I figured gonna try and swap my brake cylinders in there and redoing all the brakes and ebrake cables ect before putting in.
cory99 is offline
post #4 of 4 (permalink) Old 03-22-2017, 12:08 PM
alleged moderator
you will probably have to use the 96 backing plates on the 90 axle too. if i remember correctly 96 used larger drums also.
tom
