Nobody Likes Blue smoke! - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 41 (permalink) Old 03-20-2017, 04:47 PM Thread Starter
Tmcpherson's Avatar
So I got my 97 7.3 back from the shop. the rust work is finished and the bed is soon to be reinstalled!
I replaced the wiring harnesses under the valve covers. The truck now runs very well! It starts great and has a smooth idle. But we now have another set of problems that I hope people have experience with.
Problem one: After the truck sits running for a minute, it starts to smoke a white/blue smoke. Definitely burning oil from some place. Hitting the throttle the smoke increases heavily, but still seems to run well.
Problem two: Hitting throttle (in park) the rpms increase, then a sound of hissing/air noise. Then the truck bogs down. Hitting the throttle a little more the truck gets over 1500rpm and the hissing goes away and the truck seems ok.
These two problems may be connected or may not be, I dont know. My thoughts are maybe bad injector orings or injector cups? Maybe the turbo is leaking oil? The hissing sound maybe the butterfly valve sticking?
What do you think? any help is appreciated.
Thanks
That OBS Life
Tmcpherson is offline
post #2 of 41 (permalink) Old 03-20-2017, 05:03 PM
PSN intsigator
heavydoc's Avatar
Re: Nobody Likes Blue smoke!
Problem 2 sounds like your EBV solenoid is engaging. Unless you have already deleted it.
Sent from my SM-N920V using Tapatalk
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #3 of 41 (permalink) Old 03-20-2017, 06:44 PM Thread Starter
Tmcpherson's Avatar
I havent deleted the EBV. if this is it, how do I check? how should I go about this
That OBS Life
post #4 of 41 (permalink) Old 03-20-2017, 07:21 PM
PSN intsigator
heavydoc's Avatar
Unplug the connector coming off of the turbo pedestal.
heavydoc is offline
post #5 of 41 (permalink) Old 03-20-2017, 07:43 PM Thread Starter
Tmcpherson's Avatar
Ill try that^
So after a little reading, Im worried theres some heavy damage to my engine. Its burn a good amout of oil. So im worried that maybe I have a cracked piston or bad rings? Getting a bad feeling about this.
That OBS Life
post #6 of 41 (permalink) Old 03-20-2017, 11:21 PM
PSN intsigator
heavydoc's Avatar
If its burning alot of oil have you checked injector o-rings
heavydoc is offline
post #7 of 41 (permalink) Old 03-20-2017, 11:47 PM Thread Starter
Tmcpherson's Avatar
No I havent checked injector orings. If it have bad injector orings, wont there be oil in my fuel bowl?
That OBS Life
post #8 of 41 (permalink) Old 03-20-2017, 11:52 PM
PSN intsigator
heavydoc's Avatar
Yes
heavydoc is offline
post #9 of 41 (permalink) Old 03-21-2017, 02:01 AM Thread Starter
Tmcpherson's Avatar
Ok, so Im going to check my fuel for oil when I get home this weekend.
Now if I had bad injector cups, Then there would be coolant in the oil or the fuel? Or where would the coolant go?
That OBS Life
post #10 of 41 (permalink) Old 03-21-2017, 02:57 AM
PSN intsigator
heavydoc's Avatar
Fuel in coolant iirc.
heavydoc is offline
