97 f250 won't start please help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 03-19-2017, 06:17 PM Thread Starter
Reitz's Avatar
My 97 f250 will turn over great but it won't start. My wts light doesn't come on and my check engine light is on. Also I don't know if my rpm is where it needs to be because my tach doesn't work. Already pulled all the fuses and they are all good. Please help
Reitz is offline
post #2 of 31 (permalink) Old 03-19-2017, 07:32 PM
Re: 97 f250 won't start please help
You'll need to obtain the codes. No WTS and no tach indicate an electronic issue, either the PCM, something connected to it, or a wiring issue.
madpogue is offline
post #3 of 31 (permalink) Old 03-19-2017, 07:46 PM
79jasper's Avatar
It's best to give all the information.
Does it have a chip?
You said all the fuses, but did you check the underhood fuses?
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #4 of 31 (permalink) Old 03-20-2017, 12:39 AM Thread Starter
Reitz's Avatar
My truck has a hydra chip and I was trying to set my evolution cts2 tuner so I could see my gauges and yes I did check all the fuses under the hood and in the cab.
Reitz is offline
post #5 of 31 (permalink) Old 03-20-2017, 12:41 AM Thread Starter
Reitz's Avatar
Could it be my IDM? I took my PCM off and I found a tooth that the wiring harness goes to was bent and wasn't going into the harness. I would imagine that was my tach
Reitz is offline
post #6 of 31 (permalink) Old 03-20-2017, 01:44 AM
You mean a damaged terminal? How do you "imagine" it was the terminal for the tach signal? Based on a diagram? That would be about the only way to know for certain. But generally, if there's a damaged terminal on the connector, it could easily throw a CE light.
madpogue is offline
post #7 of 31 (permalink) Old 03-20-2017, 03:12 AM
79jasper's Avatar
Remove the chip completely then try it.
79jasper is offline
post #8 of 31 (permalink) Old 03-20-2017, 09:13 AM Thread Starter
Reitz's Avatar
I've already tried this multiple times
Reitz is offline
post #9 of 31 (permalink) Old 03-20-2017, 09:16 AM Thread Starter
Reitz's Avatar
Yeah I meant terminal and I don't really know how I imagined the damaged connector was my tach I was just assuming. But if it was that connector that was throwing the CE then wouldn't it have happened as soon as the PCM was put it. Also I had a the code p0603 before any of this happened.
Reitz is offline
post #10 of 31 (permalink) Old 03-20-2017, 01:09 PM
P0603 is just a memory error that comes up when you disconnect the batteries or disconnect the PCM itself.
Can you get a pic of the damaged terminal?
madpogue is offline
