Turbo rebuild? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-18-2017, 06:14 PM Thread Starter
Turbo rebuild?
So last night my trucks fan hit my transmission line and the line bursted and sprayed transmission fluid all over the motor. And I believe it got into the turbo as the intake pipe was wet. Now the turbo makes a screeching sound when put in drive or reverse. It doesn't do it when it is in park or neutral. Does it need to be rebuilt or will this noise go away after a while? It's the stock turbo.
1995f250 is offline
post #2 of 10 (permalink) Old 03-18-2017, 10:23 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: Turbo rebuild?
Are you sure the wetness is tranny fluid and not oil from the ccv? The screeching seems like it has something to do with your trans not the turbo. If you can rev it in neutral and the turbo doesnt screech like you say, then its probably not the turbo. Were you doing this after the lines just blew and spilled alot of your trans fluid out?
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 10 (permalink) Old 03-18-2017, 10:29 PM Thread Starter
Re: Turbo rebuild?
It's red inside the intake tube towards the bottom. The air filter had atf on it. I don't think I damaged the trans it only moved about 30 feet then I shut the truck off
1995f250 is offline
post #4 of 10 (permalink) Old 03-18-2017, 10:35 PM
Garage
Re: Turbo rebuild?
Well the atf itself shouldnt hurt the turbo, but the fact that you heard a screeching only when in a moving gear (drive and reverse) and not in park or neutral seems like a strong indication that it was your transmission not the turbo.
I would clean/replace the air filter, replace those lines and put some new atf in your trans and then see what happens.
post #5 of 10 (permalink) Old 03-18-2017, 10:37 PM Thread Starter
Re: Turbo rebuild?
I put new fluid in today along with the lines and started it up without the filter and just putting it in drive it was still doing it but wasn't as loud
1995f250 is offline
post #6 of 10 (permalink) Old 03-19-2017, 08:42 PM Thread Starter
Re: Turbo rebuild?
What could this noise be if it is the transmission?
1995f250 is offline
post #7 of 10 (permalink) Old 03-20-2017, 02:05 PM
410customs's Avatar
Re: Turbo rebuild?
noise is not there in N only in D?
Does truck drive and shift just with a noise?
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #8 of 10 (permalink) Old 03-20-2017, 02:09 PM Thread Starter
Re: Turbo rebuild?
Found out it's just a pulley. When under load it's making a noise
1995f250 is offline
post #9 of 10 (permalink) Old 03-20-2017, 02:29 PM
410customs's Avatar
Re: Turbo rebuild?
that's some good news
21.9 liter family
post #10 of 10 (permalink) Old 03-20-2017, 02:36 PM Thread Starter
Re: Turbo rebuild?
Was a big relief
1995f250 is offline
