Need help with front driveshaft to tcase - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 11 (permalink) Old 03-16-2017, 06:39 PM Thread Starter
CAT lover
Robertl211's Avatar
Having some issues with getting from my bw4406 to my front axle. My front output on the tcase is a flange with 3.5" bolt center distance and a 2inch pilot that only extends 1/8" my shaft is supposedly from a f350 it has a double Cardin joint but no face to bolt to my flange. Any solutions for this?
Also does anyone know where to get the bolts for that shaft to transfer case flange
Thanks!
96 F250 RCFB 4x4 7.3
03 Excursion Eddie Bauer 7.3
96 f350 CCLB Dually ZF5, custom flatbed, 3" dp 4" MBRP exhaust
95 F250 RCLB 7.3 4x4 conversion with 5" Sky RSK, D60 front, 18" American Racing, 35" Nittos, DIY SD intercooler, Melling LPOP, DIY 6637, Baby Swamps with TS6 and Swamps tunes, boost pyro trans
05 F350 RCLB Dually SOLD
Robertl211 is offline
post #2 of 11 (permalink) Old 03-16-2017, 06:53 PM
79jasper's Avatar
Re: Need help with front driveshaft to tcase
How did you run into this problem?
You should be using a bw1356 tcase. Which will bolt right to the front shaft you have.
You're gonna have to swap the cv head. Like this. http://shop.broncograveyard.com/mobi...uctinfo/32492/
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #3 of 11 (permalink) Old 03-16-2017, 09:34 PM Thread Starter
CAT lover
Robertl211's Avatar
Well i tried to piece together my driveline from craigslist and junkyards. Did a 4x4 swap on a 2wd truck, pain in the butt at this point in the project. im looking for a 1356 and the right shafts currently.
post #4 of 11 (permalink) Old 03-17-2017, 02:24 AM
Curious, why did you chose a 4406?
1995 Crewcab XLT 4x4 7.3, E4OD, 3.55, TS 6 chip, RiffRaff air filter.
Whoknows is offline
post #5 of 11 (permalink) Old 03-17-2017, 08:58 PM Thread Starter
CAT lover
Robertl211's Avatar
Because I didn't do my research effectively and didn't know how hard it would be to find driveshafts! Lol
post #6 of 11 (permalink) Old 03-17-2017, 11:14 PM
79jasper's Avatar
Is it even set up for manual shift? Or is it electric?
79jasper is offline
post #7 of 11 (permalink) Old 03-18-2017, 02:02 AM
You could run a 4407 or 1356, pretty sure the front driveshafts are the same for both.
Whoknows is offline
post #8 of 11 (permalink) Old 03-18-2017, 04:12 AM
csp
Yep, same driveshaft for both, but the 4407 still has to have the correct CV type yoke as the F250 did not use a CV front shaft and has a different yoke.
csp is offline
post #9 of 11 (permalink) Old 03-18-2017, 01:42 PM Thread Starter
CAT lover
Robertl211's Avatar
Ended up just finding a different tcase, going to pick it up with the shafts on Monday. The 4406 is a manual shift and everything bolts right up except for the front shaft!
post #10 of 11 (permalink) Old 03-20-2017, 03:41 AM
csp
4407 and 1356 are also manual shift.
csp is offline
