Injectors and programming - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-05-2008, 02:52 AM Thread Starter
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Can't remember, but will split shots run fine on single shot programming, or vice versa?
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #2 of 4 (permalink) Old 01-05-2008, 02:59 AM
racehauler's Avatar
Re: Injectors and programming
Yes they will run just great.
Put singles in a truck that had split's stock (SD) and they will still run but will have some weird idling usually. All that is needed is to have programing for singles on the chip in a SD and they will run flawlessly.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 4 (permalink) Old 01-05-2008, 06:27 AM
A little rough at idle. Use a 10k mod, and your set.
TerminatorEngineering is offline
post #4 of 4 (permalink) Old 01-05-2008, 08:55 PM Thread Starter
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
Thanks guys.
2005 F-250
