EBPV malfunction?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 01-03-2008, 04:33 PM Thread Starter
EBPV malfunction??
'96 psd... thirty degrees this morning in sw florida... i gave the truck about fifteen min to warm up. left the house and every time i touched the fuel pedal the EBPV would activate. doesnt matter how light i touched it either. any solutions guys...thanks
milldog is offline
post #2 of 5 (permalink) Old 01-03-2008, 06:11 PM
OBS junkie
Cat_Rebel's Avatar
Re: EBPV malfunction??
It's most likely sticking, best bet would probley be to gut it out. Someone on here can explain it better than I can.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #3 of 5 (permalink) Old 01-03-2008, 06:28 PM
<----Colin Banks
mattymx's Avatar
It will stay on with a light throttle until it warms up the oil to the desired temp. If you get on the throttle a bit harder, it should turn off until you are at light throttle. A heavy foot will turn it off. Light foot will keep it on. It is acting perfectly normal.
mattymx is offline
post #4 of 5 (permalink) Old 01-03-2008, 08:54 PM
godofdew11's Avatar
Send a message via AIM to godofdew11
i unplugged mine when it started sticking 2 years ago never looked back. looking to go with new pedistool and high flow outlet when i upgrade turbos on my 03
-Don
'03 F-350 SC LB, 4x4 7.3, loaded, 3.5" DP to 4" Ex, tymar intake, 38r, strobes and LEDs galore. windshield mount 3 gaude pod,Gearhead toonz,BTS VB, 2.5" leveing kit. Toyo 315s. Last of the 7.3's
godofdew11 is offline
post #5 of 5 (permalink) Old 01-03-2008, 10:15 PM Thread Starter
thanks for all your help i will try some things when i get home from work in the am
milldog is offline
