Turbo removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 12-31-2007, 09:00 PM Thread Starter
4x4
Turbo removal
Trying to remove turbo for EBPV delete. I assume I need to disconnect the turbo from the up-pipes at the first flange going away which has the four large bolts? If so, A: What is the trick to breaking those loose?, and B: What is the trick to getting to the bottom-left bolt which is hidden by the turbo itself?
Thanks!
Steve
1996 F350, CC, LB, 4x4, 4" lift, 35" MT's, 4.10, 3" DP, Tymar in.....
4x4 is offline
post #2 of 19 (permalink) Old 01-01-2008, 12:36 AM
racehauler's Avatar
Re: Turbo removal
It's quite an experience the first time. A short 15mm wrench and a prybar works well for the flange bolts.
Most people use a 1/4" drive 10mm swivel socket on the pedestal bolt. Be sure it's a Craftsman, Snap-On, MAC, etc. something with a replacement warranty because you WILL break at least one.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 19 (permalink) Old 01-01-2008, 03:15 PM
Re: Turbo removal
It is a fun Job, Luckely, I didnt break anything getting mine off. You will need a fer hours and a few beers...
forddieseltweek is offline
post #4 of 19 (permalink) Old 01-01-2008, 03:24 PM
<----Colin Banks
mattymx's Avatar
Re: Turbo removal
Just remember to count to 10.... Slowly.
mattymx is offline
post #5 of 19 (permalink) Old 01-01-2008, 03:28 PM
Re: Turbo removal
you should only be removing two band clamps, and the two bolts that hold the turbo to the pedistal.
PMRCM#1
slowleak is offline
post #6 of 19 (permalink) Old 01-01-2008, 03:33 PM
moose99ps's Avatar
Re: Turbo removal
i was going to say the same thing slowleak but its an obs and they use a t3/t4 type flange not like our SD turbos
early 99, xcab, 8"lift,37" toyo open country m/ts, afe stage II,BDP tuning, 5" black chrome aussie cuts, blacked out bumper and grill, 8 isspro performax guages, stealth dual pumps, a few fuel leaks......
mods to come:
NO SACRIFICE..... NO VICTORY!
moose99ps is offline
post #7 of 19 (permalink) Old 01-01-2008, 03:33 PM
<----Colin Banks
mattymx's Avatar
Re: Turbo removal
The OBS turbos are different and harder to remove. You have to remove the pedistal to get it out.
mattymx is offline
post #8 of 19 (permalink) Old 01-01-2008, 03:34 PM
Don't EFN worry about it
Aljay's Avatar
Re: Turbo removal
Yep They are attached to the ped. with bolts that go in from the bottom side up.
Tuned by T Wildman
Aljay is offline
post #9 of 19 (permalink) Old 01-01-2008, 03:37 PM
Re: Turbo removal
i just realized what i said lol. when i clicked out i realized it was an obs
PMRCM#1
slowleak is offline
post #10 of 19 (permalink) Old 01-01-2008, 03:40 PM
<----Colin Banks
mattymx's Avatar
Re: Turbo removal
No biggie. But that is not a fun turbo to remove.
mattymx is offline
