95 f250 powerstroke no fuel in bowl - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By BigVic
post #1 of 9 (permalink) Old 11-21-2015, 06:29 AM Thread Starter
Big Vic
i have a 95 powerstroke was driving it and acted like it was starving for fuel then shut off. no fuel in bowl. I am thinking fuel pump just wanting ideas on what else it could be and what brand should i go with. the truck is pretty well stock right now. any suggestion are welcome.
1995 F250 supercab 7.3l auto 2wd long bed 329,846 miles-stock-traded
1996 F250 supercab 7.3l 5sp 2wd short bed 368,432 miles,6 position chip, 3in downpipe-current
BigVic is offline
post #2 of 9 (permalink) Old 11-21-2015, 05:57 PM
mikes95powerstroke's Avatar
Re: 95 f250 powerstroke no fuel in bowl
Have you replaced it? If so where did you get it? And if you haven't replaced it, with almost 333k on it, It's very possible. Check diesel o ring out for a pump. 140$ I think? I've used Autozone pumps but haven't had the best luck.
Black truck. 350/200 S472sxe arp, beehives, pushrods, fuel lab pump, stealth twins, swamps idm. Dana60 with ox locker. 33 row dorman transmission cooler. BTS transmission. 20x12 mo970 305/55 toyo open country.
2011 f350 36xxx 20x12ís -44 leveled.
White. 230,xxx 1995 f250 Dana 60, 5inch diamond eye. 6637. Winter/work truck.
mikes95powerstroke is offline
post #3 of 9 (permalink) Old 11-22-2015, 12:02 AM
csp
Could be a pump problem, clogged pickup in the tank, bad selector valve etc. Don't just assume it's the pump.
csp is offline
post #4 of 9 (permalink) Old 09-14-2019, 02:18 PM Thread Starter
Big Vic
i know this is years later i replaced the fuel pump. when i removed the pump it was broken where it goes into the engine. it started but didn't run correctly. I sadly traded it off and did not have a diesel till i just brought another. This past sunday. I plan on keeping this one.
Blue-Truck-Nut97 likes this.
BigVic is offline
post #5 of 9 (permalink) Old 09-14-2019, 03:31 PM
Bugman's Avatar
Have you tried switching tanks?
How much fuel in each tank? The fuel pickup has a habit of rotting off on these trucks and won't pick up any fuel when the tang gets around 1/4 of a tank.
Fuel pump is also a likely culprit.
Bugman is online now
post #6 of 9 (permalink) Old 09-14-2019, 09:21 PM
RustbeltJohnny
Rustbeltjohnny's Avatar
Garage
Im going to agree with CSP. Best thing to do is check fuel pressure before the bowl, I have seen this done before but dont know the procedure and Im sure with a quick google search you could find something and while your at it also check the pressure at the bowl for reassurance.
Next I would also cycle through different tanks if you have a dual tank set up (I had this happen to me in Alaska in the middle of freakin no where) come to find out...it was a clogged pickup as CSP describes but again sometimes the selector valve near the frame takes a crap and wont send fuel up or is just clogged up.
If you do buy a pump, I recommend a pump from www.dieselorings.com He always has the RIGHT stuff, with fast shipping and reasonably priced.
Get out your pooper scoopers, cuz these suckas are talkin ####.
Rustbeltjohnny is offline
post #7 of 9 (permalink) Old 09-15-2019, 03:34 PM
Blue-Truck-Nut97's Avatar
He's already fixed and sold the truck.
OP was in 2015.
Blue-Truck-Nut97 is offline
post #8 of 9 (permalink) Old 09-15-2019, 05:44 PM
Bugman's Avatar
Also people think that the old pump is broken when the tappet comes loose from the old pump and drops into the engine oil pan. This is just normal and the pump isn't broken if this happens.
Even if this is a 4 year old thresd
post #9 of 9 (permalink) Old 09-15-2019, 07:23 PM
No no, the information definitely transcends thread age. Was just an observation. Props to the OP for remembering the thread.
