Who Can Tell Me What This Is? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-23-2007, 02:25 AM Thread Starter
Third Member
gtndrty's Avatar
While dropping in the new motor today I broke the tip off of this.
Can anyone tell me what it is and if so do you have the part #?
It's located on the drivers side inside fenderwell mounted along with the vacuum ports.
The tip I broke off has a vacuum line that goes to those vacuum ports.
TIA
http://rides.webshots.com/photo/2402...ce?vhost=rides
http://rides.webshots.com/photo/2879...Mj?vhost=rides
1995 F-350 CC 4X4, Auto, 3.55's, DP, No Kitty, Straight Pipe, Wildman 4 Position Chip, Gutted EBPV, Modded Turbo Pedestal, Autometer A-Pillar gauges, Tymar Open Element Intake, HPX Hose, Shimmed FPR, SP Diesel EBP Dongle, 466 Blue CPS
gtndrty is offline
post #2 of 5 (permalink) Old 12-23-2007, 05:04 AM
Mr. Bob's Avatar
Re: Who Can Tell Me What This Is?
Thats the Vacuum pump...
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #3 of 5 (permalink) Old 12-23-2007, 05:18 AM
Nope, not the pump. The pumps on our OBS trucks are belt driven. Must be some kind of vac sensor? I dunno.
TerminatorEngineering is offline
post #4 of 5 (permalink) Old 12-23-2007, 05:26 AM Thread Starter
Third Member
gtndrty's Avatar
I'm going to take it off and see if it has a part # on it.
I assume it has a purpose or else they would not have put it on there.
gtndrty is offline
post #5 of 5 (permalink) Old 12-23-2007, 05:05 PM
OEM Moderator
Tom S's Avatar
I think that is the sender to turn on the brake lite if the vac pump fails or there is a vacuum leak.
Tom
Tom S is offline
