Sounds like a huge air leak, no power comes and goes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 12-21-2007, 03:19 PM Thread Starter
Unhappy Sounds like a huge air leak, no power comes and goes
Hi:
I'm new to the site. Just bought a 97 E-350 with the 7.3L and Quigley 4x4 conversion. First diesel I've owned, but I used to drive a GM Diesel for work back in the mid 80s.
Anyway, warmed the truck up the this morning while I loaded up, at least 5 min.
Moved it across the street with no problem, left it running.
Pulled away from the curb and it was making a huge air leak noise, sounds like it is on the passenger side of the engine cover.
No power, so drove a 1/2 mile loop around the neighbourhood. Got close to the house and it seemed to correct it self. Drove another 1/2 mile and it started to do it again.
I'm new to diesel and turbo vehicles but I'm guessing that it is an exhaust leak, maybe a sticking waste gate?
Any other things I should be looking at?
Thanks for any help for the new guy!
Have a great holiday!
CraigH is offline
post #2 of 26 (permalink) Old 12-21-2007, 03:29 PM
Aric's Avatar
Re: Sounds like a huge air leak, no power comes and goes
It's most likely the waste gate, not sure wy it closed again. Check the Inter cooler boots just to be safe, make sure one didn't pop off. Hopefully someone with more knolage will chime in, I am fairly new to diesels also.
Merry Christmas
Aric
2000 F350 CC LB 4X4 SRW ,Lariat , Blue&Beige ,Auto , 3.73 Gears ,285/75/16 BFG's
Isspro pyro, trans, boost
AIS intake
walker BTM
71 Bronco, 351W, 3sd, 4.10 gears 33/12.5/15 BFG's
Aric is offline
post #3 of 26 (permalink) Old 12-21-2007, 05:14 PM Thread Starter
Maybe the exhaust backpressure valve has failed?
https://powerstrokenation.com/forums/...?t=3979&page=2
CraigH is offline
post #4 of 26 (permalink) Old 12-21-2007, 05:49 PM
racehauler's Avatar
Yes, this sounds like you EBPV during normal operation.
Aric - His 97 doesn't have a wastegate or IC if it is all stock. I don't mean any disrespect, just don't want any confusion.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #5 of 26 (permalink) Old 12-21-2007, 06:05 PM Thread Starter
Thumbs up Re: Sounds like a huge air leak, no power comes and goes
Thanks for the help!
How much is the exhaust backpressure valves?
Get it from the local Ford dealer?
Anyone have a pic of one so I know what I'm looking for? (I think I'm getting a service manual for Christmas...)
CraigH is offline
post #6 of 26 (permalink) Old 12-21-2007, 07:19 PM
OEM Moderator
Tom S's Avatar
That sounds like pretty normal if it was pretty cold out. It does that to restrict the exhaust flow out of the turbo to help warm up the motor.
Tom
Tom S is offline
post #7 of 26 (permalink) Old 12-21-2007, 07:23 PM
OEM Moderator
Tom S's Avatar
I just read your other thread and I think that you just might have a clogged exhaust back pressure sensor tube if you had to mat the pedal to get up a small hill. For a temp fix you can disconnect the two wire connector comming off the turbo pedestal to disable the valve.
Tom
Tom S is offline
post #8 of 26 (permalink) Old 12-21-2007, 07:38 PM Thread Starter
Question Re: Sounds like a huge air leak, no power comes and goes
Tom
It was cold out, maybe a few degrees below freezing (-2 degC), but not that cold.
I would have thought that it had warmed up enough as it sat running for about 5 minutes while I loaded up and scrapped the windows.
The second time it happened it probably had been running 10 or 15 minutes.
Do I need to watch the water temp. gauge move before driving it?
Sorry about all the questions. Thanks for your help!
CraigH is offline
post #9 of 26 (permalink) Old 12-21-2007, 07:40 PM Thread Starter
Tom
Thanks! I'll check it out. Would that explain the sound that was like a large air leak?
CraigH is offline
post #10 of 26 (permalink) Old 12-21-2007, 07:45 PM Thread Starter
Google to the rescue!
http://www.freeautoadvice.com/diesel/psdback.html
This sounds like it, other than "Also, if you put the pedal to the floor, the valve will open and the truck takes off like a teenager with dad's keys." it didn't seem like it opened when I had to use more throttle to get up the hill.
CraigH is offline
