stalling ???????????????????????????????? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 12-18-2007, 02:45 AM Thread Starter
PSN nerd
only does it on the super butt pucker program. if you run the truck hard for a min then it will act like it runs out of fuel. fuel pressure stays at 67psi the whole time, oil pressure stays right where it should be ( i have aftermarket gauge)
no oil leaks, known good fuel, like i said only on hot program.
truck will start back up after a few cranks, or if i get out of it when it first stumbles it will usually not die. today when it stalled it took a couple cranks to get it lit back up.
no cel
thinkin ipr or hpop screwin up. ipr orings were done a few years ago, truck isnt using much oil (well much more than a motor with 250k on it?) im not seeing the fuel pressure go up either so im not thinkin injector orings.
since it dosnt do it in the towing program i wonder if the added demand on the hpop system in that program is findin my weak link
i need to get another hydraulic gauge so i can see what the hpop pressure is doin. or auto E
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
JAKE is offline
post #2 of 3 (permalink) Old 12-18-2007, 02:47 AM
<----Colin Banks
mattymx's Avatar
Re: stalling ????????????????????????????????
Sounds like you are running out of HPO. Could be bad HPOP or IPR, ICP.... When did you change oil last?
mattymx is offline
post #3 of 3 (permalink) Old 12-18-2007, 02:59 AM Thread Starter
PSN nerd
that oil has about a year and 10k on it. was tested a month ago and came back great. amsoil 15-40ame
i was thinkin runnin out of hpo but the stall and no start is what gets me when it takes a few trys to get it to restart. it will try to run on the restart but not very well. and no codes. i need to get that hyd gauge set back up. im kinda leanin to the ipr f-in up and stickin open. i would love to get a pulse pump on there but the $$$ aint gonna let me.
JAKE is offline
