Easy Fuel Bowl Delete w/ Pics - Page 3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #21 of 29 (permalink) Old 03-01-2018, 04:38 PM
Jholbrook11's Avatar
Garage
Originally Posted by Lt.Dan View Post
It will be totally fine. All filters are rated at much higher pressure than the stock pump can produce.
Awesome thank you. Hoping to get this all set up this weekend. Is yours still going strong or have you converted to efuel since?
Jholbrook11 is offline
post #22 of 29 (permalink) Old 03-01-2018, 05:11 PM Thread Starter
Project Shamu
Lt.Dan's Avatar
I converted to e fuel shortly after because after removing the fuel bowl, I could see the fuel pump weeping fuel, so I decided to not reinstall another pump that would fail and be a pain to replace again.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #23 of 29 (permalink) Old 03-03-2018, 12:15 AM
Garage
Re: Easy Fuel Bowl Delete w/ Pics
Also, any tips for getting the wiring harness out?
post #24 of 29 (permalink) Old 03-03-2018, 12:15 AM
Garage
Out of the fuel bowl that is
post #25 of 29 (permalink) Old 03-03-2018, 04:24 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
I was able to wiggle mine out of there, but there is also several connectors that you won't need and you can clip them off. The only one you "need" is the IPR connector. I even took my harness apart, pulled the pins out of the plug, and re-wired them from scratch with new plugs.
Lt.Dan is offline
post #26 of 29 (permalink) Old 04-16-2018, 06:56 AM
Hey dan do u have pics and list for the e fuel i am going to do a fuel bowl delete this week and just want to do it all at once
Rob92 is offline
post #27 of 29 (permalink) Old 04-18-2018, 03:42 AM Thread Starter
Project Shamu
Lt.Dan's Avatar
https://www.powerstrokenation.com/for...l-buildup.html
This what you're looking for?
Lt.Dan is offline
post #28 of 29 (permalink) Unread Today, 06:05 PM
Looks like all the pictures from the original post are gone, do you still have them?
Scott Rodriguez is offline
post #29 of 29 (permalink) Unread Today, 07:22 PM Thread Starter
Project Shamu
Lt.Dan's Avatar
I should have them on my server, I'll check when I get home
Lt.Dan is offline
