Oil Cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-12-2007, 04:20 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Oil Cooler
How bad of a job it is to put new o-rings and gaskets in one. Mine has started leaking.
95 Ex. Cab Long Bed 4x4. Built.
01 Ex. Cab Long Bed Dually 4x4 6 Speed. Intake, Exhaust, Super Chips Tuned
Tow Mule
NyCowboy87 is offline
post #2 of 6 (permalink) Old 12-12-2007, 04:40 PM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Re: Oil Cooler
It's not fun because of the space and there is an oil pressure regulator in it that if touched will cause big trouble for you engine. That being said I believe once they start leaking you just replace the whole thing. I could be wrong but I do know that they are mild steel and rust like the Oil pans do.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #3 of 6 (permalink) Old 12-12-2007, 08:31 PM
Third Member
gtndrty's Avatar
Re: Oil Cooler
Here are some pics.
http://community.webshots.com/album/...WtvRkH?start=0
I did mine last winter. It's a bear to get in and out but it can be done.
I had to use a press to press the ends back on the oil cooler tube. They are a tight fit.
When I reinstalled it I had to jack the motor up a bit to get past the engine crossmember.
1995 F-350 CC 4X4, Auto, 3.55's, DP, No Kitty, Straight Pipe, Wildman 4 Position Chip, Gutted EBPV, Modded Turbo Pedestal, Autometer A-Pillar gauges, Tymar Open Element Intake, HPX Hose, Shimmed FPR, SP Diesel EBP Dongle, 466 Blue CPS
gtndrty is offline
post #4 of 6 (permalink) Old 12-12-2007, 08:53 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: Oil Cooler
Ok thanks for the pics. The relief valve... now do the old ones have a snap ring on them? Also how can they get screwed up?
Tow Mule
post #5 of 6 (permalink) Old 12-12-2007, 08:59 PM
Third Member
gtndrty's Avatar
Re: Oil Cooler
I've never heard of them screwing any thing up. Sometimes they fall out of the oil filter head. They are supposed to be pinged in to where they won't come out but sometimes they do. Just pay attention how it comes out when you have it removed and are cleaning everything.
gtndrty is offline
post #6 of 6 (permalink) Old 12-12-2007, 09:02 PM Thread Starter
Got Bost???
NyCowboy87's Avatar
Re: Oil Cooler
Ok then. mad matt just had me concerened with his post.
thanks again hopefully this will go some what smoothly
Tow Mule
