Fuel Pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 12-10-2007, 06:53 AM Thread Starter
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Fuel Pressure
Any idea what my gauge should be reading. Like an area that it should be running in? Really dont have the slightest clue.
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #2 of 14 (permalink) Old 12-10-2007, 12:52 PM
6.4's are my Hero.
Reubine's Avatar
Send a message via AIM to Reubine
Re: Fuel Pressure
Fuel pressure should be around 60psi.
'95 Ford F-350, CC,4x4,SWAMPS 300/200Hybrids,H-11 Head studs,Comp 910 Springs,Chromemoly push rods,modded TE 17*, GARRETT GT40 TURBO,built trans with 3 disc billet convertor,SWAMPS 6 position chip,3"DP to 6" single, IDM Mod,Gauges,'02 SD IC,Electric Fuel system and bunch of other stuff.
Reubine is offline
post #3 of 14 (permalink) Old 12-10-2007, 03:23 PM
Re: Fuel Pressure
Fuel pressure at idle should be 65to75psi
ono_55 is offline
post #4 of 14 (permalink) Old 12-10-2007, 05:54 PM
racehauler's Avatar
Re: Fuel Pressure
For optimum performance 60psi or a little above. It should run just fine as long as you have 40psi or more though. I don't know what the stock regulator is set at but I think it's around 50 or 55psi.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #5 of 14 (permalink) Old 12-10-2007, 07:18 PM
Michael's Avatar
Re: Fuel Pressure
Assuming you have the factory mechanical fuel pump, you will probably have a hard time reading the gauge unless you have added some type of snubber (orfice restriction) to the line to the gauge. The mechanical fuel pump puts some pretty big pulses on the system.
Regards,
Michael Pliska
95 F350 CC DRW, ISSPRO Performax gauges, Diamond Eye 3x4" DP & 5" exh, MBRP tip, Baby Swamps & tunes, Trans VB mods, Dunrite TC, Lock-Right, Cal-Tracs
99 Silverado race truck
96 F250 RCLB, bone stock
00 Jetta TDI, Kerma Tunes, Der Chimera Stg 3 clutch
73 & 74 Vega race cars, 92 GMC Typhoon, 73 Chevy Blazer with Pontiac 400, 73 Trans-Am 455
Michael is offline
post #6 of 14 (permalink) Old 12-10-2007, 09:17 PM Thread Starter
Re: Fuel Pressure
yea the pump is stock. When idle it bounces from about 80-85 psi. Driving its steady but it depends on how much I am on it obviously. Would a new fuel filter affect the outcome of the PSI?
post #7 of 14 (permalink) Old 12-10-2007, 11:13 PM
Michael's Avatar
Re: Fuel Pressure
Whether a new filter increases or decreases measured fuel pressure depends on whether you are measuring upstream or downstream of the filter. If your measurement point is downstream of the filter, a new filter should result in higher fuel pressure. If yours is only bouncing 5 psi, the gauge must already be providing some level of damping. With a very responsive gauge, my truck bounces about 40 psi total while idling.
Regards,
Michael Pliska
Michael is offline
post #8 of 14 (permalink) Old 12-11-2007, 02:56 AM Thread Starter
Re: Fuel Pressure
Regards,
Michael Pliska
Sorry I dont understand hardly any of that. newbs
Ok so here is another question then. How can I get the fuel pressure to drop to what some others on here said it should be?
post #9 of 14 (permalink) Old 12-11-2007, 02:47 PM
6.4's are my Hero.
Reubine's Avatar
Re: Fuel Pressure
I would leave it alone until you get an electric fuel system. If you get an electric system, then you will have a regualtor to adjust to whatever pressure. Good luck!
Reubine is offline
post #10 of 14 (permalink) Old 12-12-2007, 06:32 AM Thread Starter
Re: Fuel Pressure
alright will do then lol. So its really no problem then
