No wastegate? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 12-07-2007, 03:54 AM Thread Starter
97flatbedkid's Avatar
No wastegate?
Hey guys, just got my first diesel, new to this site, and I need some help with my truck. So I just bought a 97' powerstroke with a 5spd manual and 140k miles and its got some stuff done to the engine but I have no clue what the previous owner(s) have done to it. I brought it in to my diesel school the other day and my teacher noticed that I don't have a wastegate on my turbo. It has the little valve but no actuator. Is this a common modification? Its got a 5" straight exhaust and a chip that I can turn on from the dash, no clue what kind yet. The turbo spools up really fast even with the chip off, is this because of the no wastegate? Im a little worried about having too much boost? Is this a problem? If so should I put a stock wastegate on or an aftermarket? Thanks
[SIGPIC][/SIGPIC]
97' F-250 5 spd 4x4 Flatbed Crew Cab
-all aluminum flatbed
-5" straight exhaust
-chip
-shaved door handles
97flatbedkid is offline
post #2 of 20 (permalink) Old 12-07-2007, 04:33 AM
bigd4me2's Avatar
Re: No wastegate?
yes,i don't know about the 97,but you don't need no stinking waste gate!
you can use your foot for a waste gate,on 99-03 it is a van turbo or non waste gate housing upgrade.i think bean sells them.
useually has a larger exhuast outlet.
bigd4me2 is offline
post #3 of 20 (permalink) Old 12-07-2007, 03:29 PM
OEM Moderator
Tom S's Avatar
Re: No wastegate?
The stock turbo does not have a wastegate it has an exhaust backpressure valve to aid in warm up.
Tom
Tom S is offline
post #4 of 20 (permalink) Old 12-07-2007, 06:21 PM
racehauler's Avatar
Re: No wastegate?
Tom is correct. They may have chaged the housing out for a smaller one though to make spool up quicker though.
If you are worried about having too much boost put a boost gauge in it.
Since it is a 97 and you live in California there is a good chance that the truck is a Cali version with the larger injectors (more like the SD's have) in it. It should run pretty well with the chip turned up.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #5 of 20 (permalink) Old 12-07-2007, 08:20 PM
OBS junkie
Cat_Rebel's Avatar
Re: No wastegate?
So the OBS Powerstrokes didn't have a Wastegate?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #6 of 20 (permalink) Old 12-07-2007, 10:12 PM
OBS junkie
Cat_Rebel's Avatar
Re: No wastegate?
By the way what do you mean by
shaved door handles
do you have any pictures of this?
RIP Will Iott
post #7 of 20 (permalink) Old 12-07-2007, 11:32 PM
Re: No wastegate?
Correct.
gregrob is offline
post #8 of 20 (permalink) Old 12-08-2007, 12:03 AM Thread Starter
Re: No wastegate?
Thanks guys, so I think ill just leave it alone and just put a boost gauge in and call it good. I'll put some pics up of my truck with the shaved door handles this weekend, I see some of you are wondering.
[SIGPIC][/SIGPIC]
-chip
post #9 of 20 (permalink) Old 12-08-2007, 07:08 AM
Old But Sexy junkie!
NastyCracker's Avatar
Re: No wastegate?
Yup, I wanna see no handles =]
NastyCracker is offline
post #10 of 20 (permalink) Old 12-08-2007, 11:15 PM
OBS junkie
Cat_Rebel's Avatar
Re: No wastegate?
Originally Posted by gregrob View Post
Correct.
So does the early 99 have a wastegate or is that non wastegated as well? I thought that they used just about the same turbos that the OBS had.
RIP Will Iott
