exhaust leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-11-2009, 05:24 AM Thread Starter
EverettWV's Avatar
exhaust leak
I've notice that my truck has seemed like it has a lot less power lately and the mpg has gone down. I got looking into the problem and found this.
Found that that was cause by the rear driver's side manifold bolt's head popped off.
My question is since i will probably have to take the manifold off to get the bolt out should i replace the donut gasket? Also I am guessing that I should use some sort of anti seize on the bolts?
And from what I read on here, there was originally no manifold gasket. So should i even worry about putting one on if the manifold surface is flat?
Thanks!
Everett
1997 F-250 Heavyduty, Powerstroke, DIY Intake, 4X4, 5 speed, SWD 4:10 axle, 4" Flo-Pro SS Exhaust
Dana 60 conversion with PMF RSK with superduty V code springs, Rear superduty B code springs
EverettWV is offline
post #2 of 4 (permalink) Old 08-11-2009, 02:58 PM
Don't EFN worry about it
Aljay's Avatar
Re: exhaust leak
I was puting the manifolds back on and one of the bolts broke the head popped right off ,had to remove the manifold and dig up another damn bolt. I would slather on the anti-seize I use it on the uppipe donuts too . If Ithink I might have to take it apart it is getting anti-seize or even if not.
Tuned by T Wildman
Aljay is offline
post #3 of 4 (permalink) Old 09-03-2009, 11:17 PM
Re: exhaust leak
hello i have a leak at the joint were the mainifold meets the up pipe and was told there is no dounut gasket so was there one on urs or no
96 powerstroke is offline
post #4 of 4 (permalink) Old 09-04-2009, 03:13 AM Thread Starter
EverettWV's Avatar
Re: exhaust leak
Nope, no gasket there. They are at the top of the up pipe.
Everett
