Sagging doors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 08-11-2009, 03:42 AM Thread Starter
EverettWV's Avatar
Sagging doors
Ever since I've had my truck, I've noticed that both doors seem to sag a bit. When ever I shut the door they would go up. Well lately the drivers side door has been rubbing a bit between the lower right corner and the cab. Also it will not shut all the way. I can still see a little gap between the door and the cab.
What the best way to fix this? I have never adjust doors before and don't want to make it worse. Also it looks likes the plastic bushings that door latches onto is wore out. Where is the best place to get those.
Thanks!
Everett
1997 F-250 Heavyduty, Powerstroke, DIY Intake, 4X4, 5 speed, SWD 4:10 axle, 4" Flo-Pro SS Exhaust
Dana 60 conversion with PMF RSK with superduty V code springs, Rear superduty B code springs
EverettWV is offline
post #2 of 15 (permalink) Old 08-12-2009, 01:21 AM
STILL LEARNING
Bradbilt's Avatar
Re: Sagging doors
Go to your local auto parts store and look on their HELP rack. They make replacement pins and bushings to service fords non servicable hinges. Either that or go buy new hinges
Bradbilt is offline
post #3 of 15 (permalink) Old 08-12-2009, 02:11 AM
Patrick Feeley's Avatar
Re: Sagging doors
It's HELP! #38410. You need two per door. Cheers!
Patrick Feeley is offline
post #4 of 15 (permalink) Old 08-12-2009, 10:37 PM
Re: Sagging doors
I got new metal pins and bushings from napa pretty cheap. Do not unbolt the hinge from the door or body. Have someone hold the door while you r&r the pins/bushings. I unbolted the hinge from the door, and it took forever to get the door lined up just right.
new to me truck:02-99 f350 cclb 4x4 6sp bdp stg 1's, TW 6 pos chip, diy tymar everything else stock, that I know of, talk about bassackward upgrading, but I wanted my NEW stg1's in my 'new' truck
1064rg is offline
post #5 of 15 (permalink) Old 08-12-2009, 11:08 PM
Don't EFN worry about it
Aljay's Avatar
Re: Sagging doors
Me I grind the stock pins in half with a carbide cutter and rest the door on a stool I had that I could set the height on. Took me a little time to do it but its nice to not have to slam the darn doors.I just replaced the plastic bushing on the striker bolt today.No more rattling door. its funny how my last too trucks just the drivers side was toast. You might have to get creative to get the old bushings out of the hinge halfs. I used a long punch.
Tuned by T Wildman
Aljay is offline
post #6 of 15 (permalink) Old 08-13-2009, 02:13 AM
97 OBS PSD
Aaron Ford's Avatar
Re: Sagging doors
Are you in Morgantown or Hedgesville? I am in Fairmont. I just did mine and could likely lend a hand if necessary. I marked my doors, unbolted them and worked the hinges on the truck. The door panels did have to come off to disco the speaker wires. I work odd hours and have an outage coming up, but I am sure we could schedule something if you do not want to tackle this one yourself.
Aaron
97 PSD 4X4 250K, Ron Holland/Banks 1.00 A/R, EBPV Delete, 3" DP, Kitty Delete, PHP Phoenix 6 POS, 140V IDM, Autometers on the Pillar,4" Intake, 17 degree SD pump, 18-20 psi depending on setting...
Aaron Ford is offline
post #7 of 15 (permalink) Old 08-13-2009, 02:32 AM Thread Starter
EverettWV's Avatar
Re: Sagging doors
Did you all just replace the bottom one or both of them?
Aaron, by next week I will be in Morgantown for school. But hopefully I can get it done tomorrow with help from my dad. Just depends how things goes with getting the manifold off. One bolt had to give me problems.
I think i might try to do it by supporting the door and then cut the pin and if needed to get the bushings out, unbolt the bottom hinge but leave the top hooked on.
Everett
post #8 of 15 (permalink) Old 08-13-2009, 02:57 AM
Aljay's Avatar
Re: Sagging doors
I do them both ! But I over do some things.
Tuned by T Wildman
Aljay is offline
post #9 of 15 (permalink) Old 08-13-2009, 03:28 AM
97 OBS PSD
Aaron Ford's Avatar
Re: Sagging doors
I replaced both. Pulled the door, drilled the top and bottom, cut the factory hinge and drove the ends out seperately. First door took 8 hours, second door took 30 minutes.
I am about 20 miles south of Motown with a pretty fair complement of tools.
If ya need anything, drop me a line. I am in the phonebook. Username is the one mom gave me...
Aaron
post #10 of 15 (permalink) Old 08-13-2009, 04:06 AM
STILL LEARNING
Bradbilt's Avatar
Re: Sagging doors
Dont unbolt the hinge unless you have too(you will loose your alighnment). If you can, hang the door from and overhead rafter, garage door track, A-frame withe small ratchet straps. Just cut the center of the pins and pull them out from each end. Mone the door away from the truck. Drill out the hinges to accept the bushings, install the bushings. Swing door back to truck and drop in new pins. Should not take more than 30 min per door
Bradbilt is offline
