D60 outer tube seal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-09-2009, 09:50 PM Thread Starter
hit n miss
Peroni's Avatar
Question D60 outer tube seal
Fellas can anyone confirm that dana/spicer #50492 is the correct seal for my axle? Parts store says this is the inner tube seal. I need the outer one, installs in very end of the axle tube where the C is welded on.
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, electric fuel, CCV mod, 6.0 fan, tru-cool 4739, Swamps 175/30% injectors, stage I Stealth pump, LASB turbo, Spearco 6.0 cac, live tuned 442hp/860tq.
Peroni is offline
post #2 of 4 (permalink) Old 08-09-2009, 11:00 PM
blue99sd's Avatar
Re: D60 outer tube seal
Never seen one on a d60, they have them on the sd's.
99 PSD dually
4" lift 35' tire
4" exhaust to 6" Aussie's
K&n air filter
cc mod
Beans stage II 120hp injectors
Beans D66 turbo
ITP regulated return
updated ecm (2000 model)
reburned TS chip- 25,high idle,60,100,120,140hp
Dyno #'s 360hp and 965 ft lbs trq
blue99sd is offline
post #3 of 4 (permalink) Old 08-10-2009, 06:06 AM
OverFuelingForYourPlesure
pontiacross's Avatar
I thought the only one they have is the one on the inside where you have to pull the carrier out to replace it.
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #4 of 4 (permalink) Old 08-10-2009, 10:01 PM Thread Starter
hit n miss
Peroni's Avatar
Page 160 on Dana parts guide in the library section here. Item 90 - seal outer tube. It says part 50492 but the auto parts master catalog lists that as seal & guide tube which is item 32 part# 48773 in the dana parts guide. wtf They want to charge me a restock fee if this turns out to be the wrong part but seems no one knows what the right one is!
Peroni is offline
